Old 01-29-2017, 12:47 AM   #1
randy500
Parting out. '69 1/2 ton big block
I'm using the big block parts. Body is very, very rusty but still some good body cuts available such as bed floor, inner bedsides where they meet the floor and and taillight sections, cuts starting at $35. Seperate ads for grill at $225, bumper $100 and A/C system for $800. Let me know what you need...
randy500 is offline   Reply With Quote
Old 01-29-2017, 06:53 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Parting out. '69 1/2 ton big block
What color is the interior? Looking for blue armrests.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-29-2017, 08:23 PM   #3
hilltop55
hilltop55's Avatar
power steering box and a drag link?
hilltop55 is offline   Reply With Quote
Old 01-29-2017, 08:45 PM   #4
carbuff382
carbuff382's Avatar
If Randy500 doesn't have this let me know, I've got it.
Thanks,
carbuff382 is offline   Reply With Quote
Old 01-29-2017, 08:59 PM   #5
hilltop55
hilltop55's Avatar
Carbuff382, I sent you a PM
Old 01-29-2017, 09:58 PM   #6
Eagle9502
Randy, do you have the engine out of this truck?
Eagle9502 is offline   Reply With Quote
Old 01-30-2017, 12:47 AM   #7
randy500
Its black interior. Probably just some seatbelts are usable and unsure of the condition of those, driver retractor and cover seems usable, some rust on buckle insert tongue.
Old 01-30-2017, 12:48 AM   #8
randy500
Drag link $40, steering box, $50 plus shipping on both.
Old 01-30-2017, 12:54 AM   #9
randy500
I do have the engine, its complete, like I said I am using the big block install parts such as frame stands, motor mounts, alternator and PS mounts.
The guy says the engine runs and I believe him, it appears he used a gas can to the fuel line and cut the purple wire to the starter to start it...that stuff is obvious from looking under the hood. Engine appears all original with still installed A/C compressor and factory AIR pump and lines. Carb is not correct but still has the TH400 kickdown switch that is correct on the carb for '69
It was last registered in 2008.
Old 01-30-2017, 10:48 AM   #10
dave666693
dave666693's Avatar
If you are selling the engine, how much?
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 01-30-2017, 10:59 AM   #11
randy500
I would sell that engine for $400, I am taking it out in between now and Sunday if you want to hear it run.
I will go ahead and get it started up today and see how it runs.
Old 01-30-2017, 11:30 PM   #12
Eagle9502
I was going to ask about the exhaust manifolds but am looking for a set without the smog holes. Would you mind telling me the part numbers for the manifolds when you pull the motor?
Old 01-30-2017, 11:38 PM   #13
sherm6413
Have a nice set of black visors in it? also pics and info on seatbelts ( which ones are there), thanks
sherm6413 is offline   Reply With Quote
Old 01-31-2017, 12:29 AM   #14
randy500
Sure, I will post the numbers if I can read them, driver side is cracked...
Old 01-31-2017, 12:30 AM   #15
randy500
Visors are the worst I have ever seen...will post pics of the belts tomorrow probably.
Old 01-31-2017, 11:44 AM   #16
70STOVEBOLT
Randy, does it still have the dual exhaust hangers? If so can you get pics and a price shipped to 46562 please?
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 01-31-2017, 04:11 PM   #17
randy500
Thanks,
Mark
The truck has the thin angle bracket hangers under the cab and the thin 45 degree angle brackets behind the tire on the frame on both sides. I think they will all fit in a small flat rate box, so $26 shipped if you want them. If that's the type you are looking for I will get some pics. The later model (71-2 at least) big block brackets are much heavier brackets.
Old 01-31-2017, 05:09 PM   #18
70STOVEBOLT
Can you get pics of the exhaust hangers? I am unfamiliar with the differences. My truck is a '70 so these should work?
Thanks,
Mark
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 01-31-2017, 08:00 PM   #19
TBohne
I need a cigarette lighter wire harness, is it any good? Pics if possible, thanks
TBohne is offline   Reply With Quote
Old 01-31-2017, 08:37 PM   #20
Eagle9502
I'll get in line for the exhaust hangers if 70Stovebolt passes.
Old 01-31-2017, 09:22 PM   #21
randy500
I will look at that tomorrow and pull it if its there.
Old 01-31-2017, 09:24 PM   #22
randy500
Thanks,
Mark
I took the pictures and will post them in a bit. I am thinking the exhaust brackets are the same to 71 and then heavier in 72. I took a picture of a 72 hanger for comparison.
Old 01-31-2017, 10:17 PM   #23
randy500
Pics of the hangars the top ones are under the cab for a 72, RH side is on the right and the view your looking at is from the front of the truck, just look at one at a time to envision how they mount. Bottom left is under cab mount for 69-71 at least, that one is drivers side. Bottom right is above the axle hangar.
Sorry but I realized I need them for a truck I am building...I usually only build 72's is why I think I thought they were for sale.
I'm just posting the picture since I went out and took it and for future reference.
The bottom pictures are of the 69-71 tailpipe hangars.
Old 01-31-2017, 11:31 PM   #24
72lowlife
Hows the frame? Straight? Modified at all. Im looking for roller if possible. Main reason why I joined this forum.
72lowlife is offline   Reply With Quote
Old 02-01-2017, 12:13 AM   #25
randy500
The frame is straight and unmodified, you can see in the last post it is pretty scaly. I guess you need a half ton long bed frame?
