Old 03-30-2004, 09:31 PM   #1
Low69CST
I would spin off the engine fan and see what happens. That would be easier than making a shroud. If engine tempature is more consistant but still hot, go to a bigger fan. You said you were thinking of putting it on the outside of the radiator, you do know you have to get a different fan for the inside or outside of a radiator right? Inside ones are pullers and are the most efficient, outside ones are called pushers. Do you have a pusher on the inside?????
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
