01-31-2017, 10:16 PM | #1 |
Crate Engine options for 1966 c20
Hi, I have a 1966 chevy c20. Removed the tired old 283 and am looking at crate engines. Originally I was interested in the goodwrench 195 hp version, but after more research i stumbled upon the L31 crate engine. For about $500 more i think a roller cam and better heads is a better deal than the 195hp setup. Now for questions;
Will my SM420 bolt up to the L31 as far as bell housing bolts? Will I need a different flywheel? Clutch? Does the L31 have a tapped hole for the clutch linkage/z-bar pivot ball? Besides that I know I would need a different intake, melonized distributor gear, and an electric fuel pump. Any help would be appreciated. Thanks |
01-31-2017, 11:17 PM | #2 |
Never Ending Projects
Re: Crate Engine options for 1966 c20
Yes, the bell housing is the same.
You will need a new flywheel as you need one for a one piece rear main seal. Clutch will depend on what flywheel you get and if it will have the same pattern. Not sure on the clutch linkage bolt hole.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-01-2017, 01:52 AM | #3 |
60-66 Nut
I don't know about the crate L31 but the regular production L31's do have the bellcrank stud boss drilled and tapped. At least all the ones I have do.
I would definitely go with the L31 crate engine if it is within your budget.
02-01-2017, 07:49 AM | #4 |
You are going to need an intake for the vortec heads, the correct distributor gear for the roller cam, a plug for the hole in the timing cover from the crank sensor and an electric fuel pump. I have one in my 66 with a mild cam and it really does run well. We swapped the cam to one that was more of a carb grind.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
