09-16-2016, 10:54 PM | #76 |
Re: TR65 LS2 T56 Engine Swap 65 C10
Excellent write up.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
01-30-2017, 06:18 PM | #77 |
Thanks for this, I could not find a bit of info other than this thread on using the TBSS / SSR engine mounts! Looks like you found a fairly simple solution that's also pretty flexible wrt engine placement. How far is your oil pan from touching the crossmember with those mounts?
On a side note the brackets themselves are proving nearly impossible to find
1968 LWB C20 / AC / Wood Bed |
02-01-2017, 11:54 PM | #78 |
Thanks crakarjax,
I set the clearance at about 3/4", pan to cross member. The mounts have worked well with no trouble for several years now. They really are out of the way of everything. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
02-02-2017, 01:52 PM | #79 | |
http://www.tbssowners.com/forums/tra...or-mounts.html I'm not sure I like that bushing style for motor mounts though. It looks like they were created in response to TB owners' mounts breaking, but I think I'll go with the stock mounts and brackets at first unless I run into clearance/breakage issues. I will be running an f-body pan which is shallower above the crossmember, so I think I may try to sink the mounts into the crossmember to the point where the bottom of my oil pan ends up just slightly above the crossmember bottom. Do you foresee any problems with that approach based on your experience?
02-02-2017, 03:03 PM | #80 |
Wow, this is nice! Great work.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-02-2017, 11:41 PM | #81 |
Thanks Lo.
crakarjax, That should work. Best to hang the engine in and adjust to the clearance you want and the correct drive line angles. I really like the OE mounts, oil filled, and pretty sophisticated to isolate the engine from the frame, and out of the way. Allow the low mount for the AC compressor. Good luck, TR
05-04-2017, 06:37 PM | #82 |
Another question for you, why did you fab the driver's side engine mount? I see that the stock one is offset which is weird, but it should mount to the crossmember just fine right?
05-04-2017, 10:54 PM | #83 |
Hi Jax,
The intermediate OE drivers side bracket was not symmetric with the passenger side and would move the cross member mount to a bad position. So I just mirrored and replicated the passenger car side intermediate bracket. So that made the mounts symmetric. TR
05-05-2017, 01:15 AM | #84 |
Can you clarify what you mean by bad position? If it's just about symmetry I'll run them as-is, but if there's a clearance issue I'll cut to the chase and fab a bracket. I can't think of anything in that area that would interfere at the moment though. Thanks again!
08-21-2017, 06:23 PM | #85 | |
But Found Her 25yrs Later!
Great write up. It's cool it was your dad's truck. Glad your pictures are still up.
06-10-2018, 10:24 PM | #86 |
Truck is very impressive in person! Looks good Tim!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-16-2018, 04:34 PM | #87 |
Thanks Chris,
Looked at my wiring diagrams when I got home. So, the Vintage Air gen4 controller cuts the compressor on and off per the evaporator coil temperature. (So it runs about 1/2 the time I would say) The LS computer controls the fans based on the high side pressure in the AC. Higher pressure more fan. So for me low speed is one fan, high speed is two fans. Of course the engine temp turns on one or two fans as well but the Ac is usually more in need of them. TR
