Old 02-03-2017, 06:59 PM   #1
68 c20 cst
Active Member
Service manual suggestions
I am starting my 1st build. What is a good manual for working on our trucks? I have a 68 c20 lwb. Going to convert to swb. Drop f 2.5" r 4" with spindles frobt and springs in back. Disk brake conversion front. Just want something that has some breakdown diagrams of parts. I got bed apart so far and am starting on front end this weekend. Then cab comes off.
Richard
68 c20 cst is offline   Reply With Quote
Old 02-03-2017, 07:27 PM   #2
Shinysideup
Shinysideup's Avatar
Re: Service manual suggestions
A must have. You wouldnt believe the details!
https://www.amazon.com/Factory-Assem.../dp/B009WDMNE2
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 02-03-2017, 07:41 PM   #3
davepl
davepl's Avatar
Then number the pages and get the Assembly Manual Index from this board.
Also you'll need the factory service manual for torque values and some assembly steps. Between the two that's all I used (plus this board, of course!).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-03-2017, 07:49 PM   #4
dfwright
dfwright's Avatar
Also check out this most excellent post by Hatzie:
PDF copies of 67-72 GM truck Service Manuals
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-03-2017, 09:21 PM   #5
bthodges
Where do we get the Assembly Manual Index?
bthodges is offline   Reply With Quote
Old 02-03-2017, 09:50 PM   #6
jocko
jocko's Avatar
The Assembly Manual is useful - but I'd submit that the very first one you need is the "Chassis Service Manual" available in the link to Hatzie's pdf's in dfwright's link above. But get the Assembly Manual too... And then I'd get the Overhaul Manual. Then you can get to work!
