07-26-2016, 10:32 PM | #1 |
Radiator Replacement 1971 C10 350
Howdy folks,
I need a new radiator for my 1971 C10 with a Goodwrench 350. The one I currently have has a leak 3/4 the way up one of the side walls. I'd like to keep it reasonably priced. I know my local O'Reilly's stocks Murray brand for just under $200. I'd like to stay in the price range but wonder if there is something higher quality I should be considering? Any recommendations on sources and brands? Thanks, KS |
07-26-2016, 10:40 PM | #2 |
Re: Radiator Replacement 1971 C10 350
I just found a leak in mine! 71 C10 350ci. We are in the same boat... subscribed
1982 K10 SWB 1987 V20 - Sold - Doh! |
07-27-2016, 05:38 AM | #3 |
Champion cc369 many guys are using them .About $200.00 ebay ,Amazon
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-27-2016, 12:17 PM | #4 |
I bought this one 2 weeks ago from Rockauto. It is a 4 core brass/copper all metal radiator and it was $128 before shipping.
"VISTA-PRO 433369" {#369} Ready-Rad; Mounting: W/ 28-3/8" WIDE CORE; W/AC; W/MAX COOLING I also had to buy the 4 core radiator supports by Goodmark through Rockauto. Then I have to cut the rubber bushing down and had to cut the bottom lip on my radiator shoud. Other than that it fits fine and it's all metal (sides and core). |
07-27-2016, 01:36 PM | #5 |
One of the First
W/ 28-3/8" WIDE CORE; W/AC; W/MAX COOLING These have plastic side tanks. Probably the same one as O'Reilly's. I bought a all metal (same# but HD version) from O'Reily AP last year. It was pricey though.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-28-2016, 12:06 AM | #6 | |
https://www.summitracing.com/parts/pli-433369 |
07-28-2016, 03:57 AM | #7 |
I'm going with the Champion. What did you decide TwoFifty ?
07-28-2016, 07:39 AM | #8 | |
On a side note, should I ever decide to upgrade to a BB, would this radiator still work for those engines as well? |
08-01-2016, 12:26 AM | #9 |
Here you go: http://www.speedcooling.com/1967_197..._Radiator.html
I've been running this radiator with A/C in front of a ZZ4 350 for the past couple of years and now have over 10,000 miles on it with out any issues. It's a direct drop in. It's also a 2 core which actually cools better that a 3 or 4 core. I know it's counter intuitive. Here's some light reading on cooling. http://www.pirate4x4.com/forum/gener...rass-tech.html You can see my install on my build thread.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
08-03-2016, 07:18 PM | #10 |
Hi Guys, just unpacking the CC369 and I am not noticing the transmission cooler on the front like my old radiator had, although Champion says it has one. Am I missing something? Is the transmission cooler configuration different in these?
08-03-2016, 08:13 PM | #11 |
I just put a CC369 in my 72 C20,, the trans cooler is in the same place as stock ,, right side , below the filler neck .
08-06-2016, 06:29 PM | #12 |
Got it. I didn't realize that this didn't have an external transmission cooler. Don't externals have more capacity? Anyone had problems with the cc369 when hauling etc?
09-10-2016, 06:30 PM | #13 |
I've been having problems with overheating in my 72 K10 w/350. Just driving on slower, back roads, I'm fine, but if I go on the Interstate, or roads where I'm traveling 60+ mph for an extended time, the temp will hit the 250 mark.
Currently I have a stock 2 core, which came out of a 70 C-10 w/350 and was hoping to get a little more input on that 3-row Champion CC369. Will it drop right in, and stock rad hold downs will bolt right up still? I'd go 4-row, but then I'd need to track down the 4 row hold downs
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
09-12-2016, 12:19 AM | #14 |
It's counter intuitive. 2-row will cool better. Some light reading.
http://www.pirate4x4.com/forum/gener...rass-tech.html I've been running this in my 72 GMC with a ZZ4 Tuned Port for over 10k mile in good old "HOT" West Texas with the A/C running with ZERO issues. http://www.speedcooling.com/1967_197..._Radiator.html
09-12-2016, 08:43 AM | #15 |
Old member
This looks like a heck of a deal.
I bought just the radiator for my 71 over a year ago from these guy's and it's a great radiator. I had dual fans already. I may order this one for the ramp truck though. http://www.ebay.com/itm/161993602251...%3AMEBIDX%3AIT
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-04-2017, 02:07 AM | #16 |
Hey guys I have a 1969 c20 with a v8 and air conditioning. Im trying to figure out the best replacement radiator for it. Copper/brass or aluminum?
02-04-2017, 02:33 AM | #17 |
I had a cooling issue with my 67 camaro and followed everyone's advice , but ended up buy a aluminum radiator from engineering cooling products. It was day and night difference. Runs 160 all day now. My old radiator was gone through from a local shop but always ran hot in traffic but would cool back down on the open road. Should have never wasted the money redoing the factory radiator. When I get closer to firing up my 72 k10 I'm buying one from them. There out of Chicago and it's made there in house.
