Old 01-31-2017, 05:33 PM   #1
AnobleL74
alternator warning light help request
My 66 c10 has a recent crate 350 with a march pulley system and alternator.
my wiring under dash is a mess, with China fuse box and only the main wiring to drive the truck is correct. The warning light wires and sockets are not there at all. i want to run direct wires and sockets etc from alt. to dash warning light. but am confused of the correct wiring route and hook up.
i have all the diagrams and books on the truck , but my lack of tech skill and knowledge make me very nervous on doing this.
would appreciate a simple layman list of instructions of what to wire point to point.
thanks Allan
AnobleL74 is offline   Reply With Quote
Old 01-31-2017, 08:32 PM   #2
jtrichard
Re: alternator warning light help request
What alternator you running? plug in rear oem with external reg.? OR plug in side (at rear) built in reg.? OR one wire?
jtrichard is offline   Reply With Quote
Old 01-31-2017, 08:41 PM   #3
AnobleL74
it has a large red wire running down the intake toward the firewall. , and a black ground to the water pump bolt.
thanks
Allan
Old 01-31-2017, 09:07 PM   #4
jtrichard
Sounds like a ONE WIRE alternator you CAN NOT run charge light with one wire
Old 01-31-2017, 10:11 PM   #5
jtrichard
Add on VOLT meter would be your best set
Old 02-01-2017, 09:39 PM   #6
AnobleL74
thanks for the help, will go with voltmeter
Old 02-02-2017, 12:30 AM   #7
Kenfuzed
Kenfuzed's Avatar
Check if your alternator also has a 2 prong connector. Some newer alternators are convertible to allow for either the one wire connection or 3 wire (like mine). If so you can add the wiring to make it a 3 wire set up.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 02-04-2017, 08:27 AM   #8
AnobleL74
thanks all , i am going with gauge set voltmeter, found some nice small size by auto gage
