Old 02-05-2017, 06:57 PM   #1
keystoneGerm
Re: My contribution to a better society
Worked on the harness today. All day spent on just the A/C portion. I rerouted under the air box, reloomed with nice loom and heat shrink all ends. Got rid of the junction block on the firewall, so ran my last fuse off the alternator. Now I am working on the transmission wiring for the kickdown and torque converter lockup. Anyone know what the red 2 wire plug is for the transmission?
These connectors are awesome to depin to do the wiring reloom. I am used to garbage Volkswagen pins that get stuck on the reg.
keystoneGerm is offline   Reply With Quote
Old 02-06-2017, 12:52 AM   #2
keystoneGerm
I used this diagram to figure out my lockup. Thanks to another member here on the board, and Google images. I fully deleted the ECS distributor wiring.
I got the rest of the harness roughed in. This one is going to be a ***** to loom. Fuses are already connected and can't depin, the oil pressure switch and sender can't be depinned. I may cut and resolder to get the heatshrink on at the same time extend or shorten as needed.
Time for bed.
