Help installing kick panels
I've looked and searched the site and googled but could not find any write ups or how to's on installing the kick panels where they are secure and stay in place, do you use trim glue on the back side or sheet metal trim screws to hold it in place ??
Any tips/tricks help Thanks |
Re: Help installing kick panels
http://67-72chevytrucks.com/vboard/s...d.php?t=271066
this is one I saved for my own reference later hopefully it helps
1969 Chevy C10 2wd stepside longbox |
Thanks for that right up but I'm looking for tips on getting the interior kick panel Trim piece like this but no speaker to stay securely in place.
![]() Join Date: Oct 2009
I just installed kick panels with speakers. I drilled through where the bracket for the kick panel vent handle goes, and and then screwed that bracket through the kick panel into the sheet metal behind it. They are nice and secure. I also have the Dodge Dakota push-on door seals, which nicely fit over the edge of the kick panel and give it a very finished look.
1971 C10 Longbed, 350/TH350 |
Nice, thats what I was debating on doing either using Trim screws or whether strip adhesive, I have no clue how they mounted these things from the Factory I couldn't see any GM Plastic Trim holes like the door panels have to hold it on.
I'm going to start looking around for some Black Trim Screws so everything Blends in well. Thanks |
#6 | |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#7 | |
Actually just found another thread about this...looks pretty slick.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 04-29-2014 at 11:09 PM. |
#8 | ||
Thanks again for the great tips guys |
![]() Join Date: Jun 2012
I used 3m velcro on mine...3 pieces on each panel and stuck it right on the steel. Been on there a year or so and havent moved a bit. That way you can always remove them if you need to
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
///Relaxed Atmosphere
same here no problems very easy.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
Y'all have any pictures you could share of the velcro installation? Looking to install kick panel speakers w/o drilling a bunch of holes.
#12 | |
Attachment 1617850
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens Last edited by sKnNyPpY; 02-02-2017 at 07:36 PM. |
Thanks man! Looks good. I'll post some pics of my progress.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
That sounds like a great idea.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#15 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
