Old 02-06-2017, 09:03 PM   #1
Vic the Chick
New printed circuit board and tac
My 72 did not come with a factory tachometer. Right now I have one on the column but am looking for a cleaner look. I am replacing the printed circuit board (bad connections, etc) that supports a tac and wondering if I can just "plug and play" the new tac or if there is something else I will need to do?
Thanks in advance!
Vic the Chick is offline   Reply With Quote
Old 02-06-2017, 09:25 PM   #2
El Dorado Jim
Re: New printed circuit board and tac
sub'd
El Dorado Jim is offline   Reply With Quote
Old 02-06-2017, 09:48 PM   #3
boynton
boynton's Avatar
you will also need an new tin and plexiglass piece (it has the numbers printed on it. LMC sells a complete kit for around $299 that includes a tac, tin, circuit. You can also look around in the parts for sell forum and try to piece one together.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-06-2017, 09:51 PM   #4
boynton
boynton's Avatar
here is their add. I know there are several other companies out there that offer the same but this is the one I know of.
1970 SWB Step-Side
