Old 01-21-2017, 05:44 AM   #1
sharkskinman
Air ride stock otherwise
65 coil springs..no mods to suspension at all
No notch(yet) no drop member..
Ss7s front ss8s rear..
Do y'all use cups out back or just in replacement of coil springs
Ride height 5-7 extended..
I want to be 1-2" s from hitting axle on the frame (for right now)
Even line front to back
Just buy 4 mounts , shave front cup if needed and do or don't use rear cups??
sharkskinman is offline   Reply With Quote
Old 01-21-2017, 10:55 AM   #2
verdell
verdell's Avatar
Re: Air ride stock otherwise
I used a something similar to these, made them myself though.
http://www.ebay.com/itm/Chevy-C10-Re...9XPg85&vxp=mtr
verdell is offline   Reply With Quote
Old 01-21-2017, 11:29 AM   #3
jweb
jweb's Avatar
I just bought these http://www.ebay.com/itm/63-72-Chevro...item2a6a61421b
I plan on using SS-7 bags all around. You can eliminate the rear brackets and mount the bag directly to go lower, but you will need a notch.
jweb is offline   Reply With Quote
Old 01-21-2017, 05:12 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
I just used the top mounting cup to provide access to the air fitting and the bottom is directly mounted to the trailing arm...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-05-2017, 12:11 AM   #5
sharkskinman
With that setup how low do you think it goes from stock height
Or how much space do you think you have until you hit frame to the axle?
What is your ride height and what is the height of the bag at ride height?
Old 02-06-2017, 07:58 PM   #6
sharkskinman
I've also read that u can use stock front shocks for the lowered back?
What about front shocks? Any other car/truck stocks work?
Old 02-06-2017, 11:37 PM   #7
vin63
vin63's Avatar
I don't know what the difference in suspension height to stock mine is. Below is a photo of my truck at ride height. For shocks, you'll need to make sure the length of the rebound and compression stroke accommodates your suspension travel. In my case, I installed the shock mount relocation kits front and rear.
