Old 02-07-2017, 10:01 PM   #26
dmjlambert
dmjlambert's Avatar
Re: Engine temp sending unit
Originally Posted by lugnuts09 View Post
Does anybody know what the fitting looks like that attaches to the this? It's the temperature sending unit.
Like this:
http://www.clipsandfasteners.com/GM_..._p/r5665pt.htm
http://www.classicindustries.com/pro...s/ca34620.html
Old 02-07-2017, 10:14 PM   #27
lugnuts09
Thank you very much. I've been looking all over the place and haven't been able to find what it looks like. I wasn't sure if I just wrapped a wire around it or what. Will this work for a 1969 c20?
lugnuts09 is offline   Reply With Quote
Old 02-07-2017, 10:28 PM   #28
dmjlambert
dmjlambert's Avatar
I suspect it would. I am thinking the wire goes into the terminal block at the firewall with one of these
http://www.classicindustries.com/pro.../wc500115.html
Old 02-07-2017, 10:33 PM   #29
Boog
laying low
Boog's Avatar
You can probably pickup the connector at a parts store. Also in a pinch you can use a regular female blade connector. Just spread it open a tad and it will slip right over.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-07-2017, 10:35 PM   #30
El Dorado Jim
wrecking yard item..
El Dorado Jim is offline   Reply With Quote
Old 02-07-2017, 11:48 PM   #31
lugnuts09
I appreciate all of the help. Going to order the parts soon. Just picked up a new radiator, heating core, thermostat, and temperature sending unit.
