Old 02-02-2017, 09:48 PM   #1
tucsonjwt
Broken grease zerk on slip yoke
My 83 C20 has a sheared off grease zerk on the slip yoke behind the center carrier. This appears to be a welded on zerk, not a threaded in one, so there is no option to just unscrew it and install a new one.
Does anybody have a fix for this? If there is no fix, should I just wait for it to seize up and then buy a new one, or should I buy a new one now? Where would I find a new one?
tucsonjwt is offline   Reply With Quote
Old 02-03-2017, 02:35 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Broken grease zerk on slip yoke
Can you tap the hole and install a threaded zerk fitting?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-03-2017, 05:42 PM   #3
tucsonjwt
I thought about that, but it seems like you would introduce metal shavings into the yoke. I never had one apart to look inside, so I don't know if it is completely hollow and really "cleanable."
Here is a pic. I think the mechanic who replaced the clutch let the driveshaft hit the concrete and broke it - but that is just a theory, since that is the only work I had done on the truck since last year when I greased the yoke last.
Old 02-03-2017, 10:51 PM   #4
Jeff's bowtie's
Unscrew the tin collar off and pull the slip yoke off drill it and tap it out replace with new grease zirk and flush the inside out with parts cleaner
Jeff's bowtie's is offline   Reply With Quote
Old 02-04-2017, 12:02 AM   #5
bilfman
bilfman's Avatar
Load up your drill bit with grease , it will capture most of the shavings.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 02-04-2017, 06:48 AM   #6
bonehead
bonehead's Avatar
Use a left-handed drill bit greased up to catch the shavings, drill it dead center. A lot of times the broken zirk will back right out as you drill. if not retap it and install a new zirk
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 02-04-2017, 01:15 PM   #7
68Timber
68Timber's Avatar
Nothing wrong with blowing it apart to drill and tap if you don't mind the labor but I'd be comfortable greasing up a drill bit as others suggested.
John
74 Honda Z50 build
Old 02-04-2017, 03:27 PM   #8
tucsonjwt
Thanks for the tips. Upon further cleaning, it looks like the driveshaft let loose on the road - probably while the clutch mechanic was test driving it after repair. My guess is that the center carrier was not secured and broke loose. So, I probably have spline damage which is unseen. The new pic shows that the yoke was clearly dragging on the ground.
Old 02-04-2017, 03:30 PM   #9
tucsonjwt
So, any thoughts on how long this yoke will survive without new grease? I suspect that if I pull it apart the spline will show so much damage that it will need to be replaced. I wonder of the damaged spline will ruin the mating female part on the end of the front section of driveshaft - if it has not already ruined it.
Old 02-05-2017, 12:01 AM   #10
68Timber
68Timber's Avatar
If you're concerned that it's junked, I'd pull it and take it to a driveline shop and let them give it the once over. It'd probably be fine with a new zerk fitting and getting balanced.
John
74 Honda Z50 build
Old 02-05-2017, 04:11 PM   #11
tucsonjwt
After further consideration, I don't think the zerk can be replaced. If I drilled out the existing zerk enough to install an new zerk, I would be left with a hole on a round surface which really can't accept a zerk thread. I would need some sort of square and flat boss to get a flat surface to drill through.
Old 02-05-2017, 06:54 PM   #12
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: Broken grease zerk on slip yoke
Just an idea that I would try.
grind it flush with the shaft. use a center punch to make a dimple. use a small drill bit to make a hole. then use an easy out.
it might not work I know how things like this go.
but as said above if you are worried about damage then the best thing to do would be to take it to a shop and get it checked out
let us know how how it turns out man
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 02-05-2017, 07:11 PM   #13
tucsonjwt
That is what I was thinking. The "grind it flush with the shaft" part that concerns me. If I get a flat surface flush with the round shaft and get a hole sufficient to accommodate a new grease zerk, I think that would get me down to a round surface again.
I emailed a local driveline shop to get their advice and find out if these yokes are still available and whether I should drive it until the thing seizes up. I have greased the thing every year so it does have grease in it, and I only drive less than 1000 miles per year.
Old 02-05-2017, 08:40 PM   #14
hatzie
Moderator
hatzie's Avatar
The broken Zerk should already have a hole dead center. The metal you see is from the threads unwinding like a slinky then bending over the grease hole... or just good old fashioned crud
Use a LH drill bit. It'll likely back right out of the shaft. Then thread a new one in.
If the shaft got dragged on the ground the tin cap would be beat to death and the abraded portion would not be nice and neat like you have there. The carrier bearing retainer would be beat to heck too. It looks like someone had the same issue as you did and got a little ham handed with an angle grinder or the last balancing job included removing a small amount of material from the shaft in that location.
I've had gators and other low lying road trash on the interstate biff that zerk off the shaft, more than once, when I couldn't change lanes to avoid em.
You're spending a bunch of time worrying about what could be wrong. That's counterproductive. Take the prop shaft off and pull it apart. If it's fouled up it ain't gonna get any better while you worry about it. If it's fine, and I suspect it is, you can drill the damaged Zerk with a LH spiral drill bit and replace it. It'll likely back right out with the drill because it's soaked in grease.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-05-2017, 09:17 PM   #15
Nessmuk
You can't get grease in it with one of the ends in a harbor freight grease gun adapter kit? I get a fair bit of use from mine.
Nessmuk is offline   Reply With Quote
Old 02-06-2017, 04:45 PM   #16
tucsonjwt
The picture does not show the zerk very well. The zerk was in perfect condition last year (prior to clutch replacement) and I grease the chassis myself (including this zerk) every year. There is no hole left in the zerk - the zerk is completely ground shut - so no opportunity to use this zerk anymore to grease the yoke. (I suppose I could grind it off, drill a center hole, and use a needle pin style grease fitting for my grease gun, but I hate using those things - they always just seem to spit grease back out at me.)
I got a nice email response from a driveline shop in town I have used in the past. The tech who responded said (as I suspected) that the yoke should be removed to inspect for spline damage. If the spline is OK, then he says he can replace the zerk (but I asked him how he would get a conventional square bottom threaded zerk in there.) He said many of these old yokes are discontinued parts, and C20s used about 5 different styles of yokes. He may have a used yoke that would work, or may still be able to get a new one. I am waiting to get an estimate for the inspection/repair at his shop.
Abrasion on the cap and in front of the zerk indicates to me that it was dragged on the ground - it is all perfectly lined up - although I suspect that it was a "light hit" as they say in the salvage yard business.
We do not have gators in this part of the desert, but it might have been a chupacabra. I never drive this truck out of the city so a significant road debris impact is not likely.
Thanks for all of the input. I am not worried - just trying to get as much data as possible prior to taking it in for a wallet flush at another mechanic.
Old 02-08-2017, 12:50 AM   #17
hatzie
Moderator
hatzie's Avatar
Gator is a slang term for the dually casings left behind big trucks...
