#10 | |
![]() Join Date: Feb 2009
Re: 71 Turbo 400 Kick Down Harness
Bummer dude, it's supposed to be "oh yeah works great no matter what you do"..........I'm a novice, but perhaps that was at the solenoid because it wasn't working as intended. Did you use the same solenoid? No sign of a ground wire. Apparently it's grounded by the chassis. I'm just taking a stab at this.....At some point this transmission will be off the truck. I've never so much as pulled a pan, but seems the solenoid would be an easy replacement, so long as it's the right part(s). I believe the single terminal is the detent? Anyway, seems the solenoid with the single prong and the right wire connects should do the trick. That's how my 72 is set-up and it works Could be a mod. This may be the solenoid, but there's probably more to this. Any additional insight appreciated. Has to be some transmission guys out there. http://www.ebay.com/itm/Turbo-Hydram...3D181397856832
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-09-2017 at 02:13 AM. |
