just got my c10 long box, it's completely straight and i want to do a 2/3 drop. can i do this with new springs&shocks or do i need new spindles up front? i'm on a budget and this is new to me. i want to be able to keep load capacity if possible. who do u recommend for a kit? any help is appreciated
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
Yes you can do the 2/3 with springs and still have a good load capacity. go to the suppliers on the home pagr they all have what you need WES at HEARTBEAT,GMC PAUL,MOTHERTRUCKERS all sell good quality stuff and can help you out
------------------ 71c10 350/350 air ps pb 320hp crate 2004R tranny from FB performance 410moroso posi completely rustfree body 27T coupe chopper 6.5 inches channeled total height 41inches powered by bigblock Edsel punched out to 490ci topped with 6stromberg97's built back in 67 Whizzer motorbikes 6or7 71C5 Blazer 350/350 needs rust repair but runs new 74Pinto stationwagon daily driver
71c10 350/350 air ps pb 320hp crate 2004R tranny from FB performance 410moroso posi completely rustfree body 27T coupe chopper 6.5 inches channeled total height 41inches powered by bigblock Edsel punched out to 490ci topped with 6stromberg97's built back in 67 Whizzer motorbikes 6or7 71C5 Blazer 350/350 needs rust repair but runs new 74Pinto stationwagon daily driver |
thanks for the info. will i have to worry about front alignments etc.
I would personally go with a drop spindle in the front. It does not change anything in the suspension but where the centerline of the wheel is on the spindle. You can then use factory springs, shocks, ect. When I do mine I'm gonna use drop spindles and lowering blocks for the back. This way I don't have to worry about getting speical springs, shocks, and what not. Just my .02
![]() ------------------ http://hometown.aol.com/racedvl/racedvl69index.html Crystal Lake IL. 30 Miles north of Chicago |
Will you be doin it yourself? Also what is the cost? I looked at Early Classics, they have a 2/3 drop kit that is coil springs and shocks. Are you getting a kit or do you have to build the parts list? Thanks for the input.
Strongman Garage
![]() Join Date: Apr 2000
also with drop spindles you can convert to disk
but yes you can do a 2/3 drop with just springs and shocks no problem ------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
This drop was done with 2.5" spindles from Early Classics. I also cut one coil. The rear is 4" springs. I haul a car trailer and a boat. I also replaced the front with a complete xmember from a 75 1/2 ton.
------------------ 68 Chevy l/b, 4 whl disc in the foothills of No Calif
68 Chevy l/b, 4 whl disc in the foothills of No Calif |
Registered truck nut
Something to consider. I just put a 2-4 drop on my buddies 66. Do to his old springs sagging, after putting in the new drop springs it only lowered the front 1/2" and the rear 2".
------------------ MOUNT VERNON, WASH. STATE GOT MY BASES COVERED -Big and bad 70 CST Blazer -71 K5 Blazer, 350, 4spd -Work in progress 72 SWB -72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd. -71, 3/4 ton, 402/400, Custom Camper -69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER" -69 Chev., lwb, utility trailer, 35" tires, -88 1ton BB workhorse Add or Delete Daily
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
i talked to gmcpaul at carlisle about springs and he said the same thing.he recomended finding a restored truck like yours and measure from wheel opening to ground and comparing it to yours to check how much it's sagged befor buying springs sometimes a 2" drop spring will actually raise an old truck because it had sagged 3" from original height!
