Old 07-13-2015, 11:52 PM   #1
68shortwide
68shortwide's Avatar
Pics of your AirRide control system?
My Avs controller is acting up and I'm not a giant fan of handheld wired controllers anyway, so I debated doing an In-Dash switch and gauge set up. I don't plan on expensive or difficult set ups, just 4 switchs and 2 gauges. Any pics of how you did yours? Or any that you've seen and saved? Thanks.
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 07-14-2015, 08:03 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Pics of your AirRide control system?
Contact member way2lo2 for a simple manual valve set up.
He's a member?vendor here.
http://67-72chevytrucks.com/vboard/s...d.php?t=575686
Keith
Convert to disc brakes.
Old 07-14-2015, 09:14 PM   #3
68shortwide
That's almost exactly what i was thinking of. Just wanted to see how other's had done it, will definitely get ahold of him.
Jack
1968 swb on air
Old 10-17-2015, 03:30 AM   #4
BigMike
BigMike's Avatar
^^^BUMP^^^ Interested in this as well.
BigMike is offline   Reply With Quote
Old 10-18-2015, 10:59 PM   #5
CMFT
CMFT's Avatar
Here's a pic of Hales Speed Shops standard setup, had it on 2 of my trucks and have been very happy with it.
'58 Apache
CMFT is offline   Reply With Quote
Old 02-09-2017, 01:47 AM   #6
68shortwide
Bump. Still haven't done anything with it,and Accuair's remote is still out of my price range lol.
Jack
1968 swb on air
Old 02-09-2017, 03:37 AM   #7
BigMike
BigMike's Avatar
I finally bought the Accuair E-Level setup and love it. Here is where I mounted my controller because I got tired of it sliding round on my bench set. I screwed a metal plate to the back of the controller with 2 very strong magnets stuck on with double sided tape. Then made a plate that slides in between my dash cover and my aluminum overlay that I painted to match the interior. I still need to take it out and paint it. I can pull it off, unplug it and throw it in my pocket, works great. Does not interfere with the door, my knees or anything else. I have rubber pads on the bottom of the magnets so when I paint that plate it won't get scratched too bad.
Old 02-09-2017, 11:11 AM   #8
JWall
Frequent Flyer
JWall's Avatar
Switch for front, rear, & compressor cut off switch.
I wanted them hidden.
I like the "safety rings" on the switch panel for the purpose of easily feeling where your hand is on the switches & would also keep them from being bumped if you had a middle passenger.
Dual needle air gauge in lower left corner... visible from drivers seat but very unnoticeable with the door closed.
- Justin
1 Owner 1976 SWB
Old 02-09-2017, 12:39 PM   #9
SCOTI
SCOTI's Avatar
Dual needle gauges (I don't smoke) & manual paddle valve switches under the seat frame...
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
