56 - autocross
72 cab and want a 67
Have a 72 cab and want to make a 1967 font clip. Will it work if I get fenders, core support and hood? 72 outer cowl also or get a 67?
Don't have doors either. Will any year door (67-72) fit a 72 cab? I know that Brothers or LMC lists 72 doors separately than 67-71. What is different? Thanks in advance. |
Re: 72 cab and want a 67
As far as I know the cabs are the same, so the 67 front end should bolt right up. Buy 67 fenders, hood, core support, and cowl( I don't think there is any difference between 67-72 cowls) and you should be good to go. 67-72 doors will fit but the 72 door panels bolt up different than the 67-71. So if you get 72 doors you need to buy 72 door panels. Hopefully someone else will chime in and say I'm right or call out my wrongs.
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie ![]() |
#3 | |
http://www.lmctruck.com/features/cb/cbhlr.htm
Scott |
#4 | |
The Older Generation
The core support mounts are different. The '67 mounting pads are about a 1/4" thick and the '72's are 3/4" to 1" thick The holes in the frame brackets are also different, the holes in the '72 brackets are larger than the '67. Here is what member Green Machine said back in 2008: Quote:
![]() Join Date: Nov 2004
67/68s also have a "splash apron" that bolts to the core support on the bottom.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
