Active Member
![]() Join Date: Feb 2017
What Rally Wheels???
Because I am new to Chevy, this is probably a dumb question. I just do not know which parts interchange with what year models. Which 6-lug Chevy rally wheels will work on my 67 C10? I like the wheels in these photos, and because the axles are so short on these old trucks, do I need wheels spacers to get them out a bit. I expect they are 15 inch wheels and expect they are 7 or 8 inches wide. What all do I need to get this look on my rig?
Oh and what tire sizes should I be looking for for this set up? Thanks alot! Last edited by the67Beast; 02-14-2017 at 08:04 AM. Reason: Need tire size too |
Re: What Rally Wheels???
I run the 4wd square body rally's on my lowered 69 with no issues. on the rear. I run 265/75 15 tires in them. Ran them on all4 corners till I lowered it. Now I have 5 lugs on front from 2wd pickup. Van ones are 7' truck ones are 8'.The truck wheels look better with the extra 1' dish
common sense isn't so common anymore |
You don't mention anything about your truck, but I have a 72 Blazer 4WD and I've got rally wheels from a square body (73 and up) running 12.50 X 33 BFG all-terrain radials. 33 is about as big as you can go without a lift.
You shouldn't need any spacers to run rally wheels. |
![]() Join Date: Nov 2001
The 6 lug Rallye's are from 73-later 4x4 pickups they are 8" wide.
Now, there are 7" wide 6 lugs Rallye's out there from mid 70's Blazers. But they are hard to locate.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#5 | |
![]() Join Date: Aug 2003
Here's a pic of mine.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
Active Member
Thanks for all of the information. My truck is a 2WD with skinny steel farm wheels on it. They are just tucked up under the wheel wells alot. I just want to get the tire/wheel combo out a bit closer to the edge of the fender not sticking out in any way. From the sound of the information, I will need to be looking for a set of 73 thru 87, 8-inch wide, 6-lug truck wheels. Here is a picture of my rig...
When you get those fancy rallies why don't you just box those nasty ol' grandpa hub caps up and send them to me.... since you won't be using them any more.
![]() ... and really nice caps. |
Active Member
Hey "Firedemon" what size tires you running on your truck. That's a nice looking rig.
That is one awesome little truck! The 6 lug 8" truck rallies will look great on it. I believe that the track width is a little less than the 71-72 trucks, but when you get the 8" rallies on it, the wheels will sit farther out and fill the wheel wells a little better. I am running them on my '68 shop truck with 275/60/15 tires and I am very happy with them. It's hard to beat the truck rallies...
Sweet ride man. Have fun with it. Jon |
Active Member
UPDATE!!! Found a set of rally wheels and got them bolted on this afternoon. WOW what a difference a set of wheels and tires makes in the appearance! I will have to wash them up and get some new centercap, lug nuts and a couple of trim rings, but I am diggin the new look! Thanks for all the advise and help with my rally wheel selection. Guess I got an original set of wheels and a set of hubcaps for sale now!
Save your old wheels and hubcaps .probably already have a lotof pm on them. They are worth more than that set of rally wheels.
laying low
![]() Join Date: Mar 2001
Instant improvement.
Active Member
"1968aj" I though about keeping the originals, but if I am to be honest with myself, I would never use them again unless it is for a wagon or trailer. They would end up taking up space in my garage and collecting dust. If I can help someone else out by selling them, then that's OK. How much you think they might be worth??
I do like the new sporty look with the rally wheels though. Fills up the wheel wells nicely!! Thanks |
255/70/15 on 8" ralleys, not sure what they came off of but I like 'em.
I wouldn't sell the original wheels and hubcaps, keep them with the truck they belong on. ![]() |
#15 | |
#16 |
![]() Join Date: Jun 2016
Rally's are awesome and are worth a little TLC - The ones on my 69' Burb were beat to hell, but I spent an afternoon cleaning, sanding, cleaning and then painting them with Eastwood's Silver Argent. Well worth the effort as they look night and day different!
#17 |
any chance you have any 15x10 5 lug sitting around taking up space you want to get rid of that look like these???
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 02-20-2017 at 04:26 PM. |
#18 |
I run rally wheels on my K10 with 35's...goes down the freeway nice and straight and no vibration even at 70 mph.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
#19 |
So if I am looking to replace my wheel vintique, 6 lug rallys with a 6 lug, OEM rally wheel, what are my options? The wheel vintiques have to much lateral runout and give me a bit of vibration at highway speeds. I have disc brakes up frort so I need to have 4" backspace.
#20 | |
![]() Looks great!!
#21 | |
Chris |
#22 | |
Thanks for the compliment.
#23 |
Instead of starting a new thread, I thought I would just continue off of this one since it's close to the same subject.
I am looking at purchasing rally wheels for my 72 Chevy C10. I've been looking at the ones on summitracing.com. I have a few questions as I am a newb when it comes to classic chevy tires. Set-up and wants: 72 chevy C10 factory height but the rear is a bit raised due to heavy duty coil springs. I would like to put 275/60's or 255/60's on but am open to opinions. 15x8 rims Questions: -Is there a cheaper place to purchase 42 series rims? -Do they all come with the -12.mm offset? Or, can you select a different offset? -What is the factory offset? -Will a 275/60 tire be too much tire? |
#24 |
I have these same 15x8 five lug truck rally wheels but am really not a fan of the center caps. Are there any other options out there I can run?
#25 |
How did I get this OLD!
![]() Join Date: Dec 2014
http://67-72chevytrucks.com/vboard/a...=1&d=149074720.
I ran 15X8 rallies with rings and caps for 1 season them added 67 full wheel covers to the rallies for a more period correct look. Like you "67 beast" I like the wheel wells filled out too. I acquired a pair of 15X10's. Thinking of wrapping them and putting them on to fill out a bit more. Keep your caps. They don't take up much space. Just in case you change your mind a few years down the road. Getting harder to find all the time.IMO Very nice truck by the way! ![]()
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
