#826 | |
![]() Join Date: Mar 2007
Re: 53 Surburban "Family Truckster"
Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#827 |
![]() Join Date: Jun 2015
Nice work on the rear end. I took the easy route and bought a moser 9" for my truck project. But threads like this get my juices flowing. I have a 71 Camaro on deck and I'm thinking I will rebuild the stock rear end on that.
#828 | |
Thanks Marc
#829 |
That's one good lookin rear end
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#830 |
I put a little garage time today. I re-installed the rear end. It confirmed some things and identified some new challenges...Ok so for the good. It looks like my measurements to shorten the rearend were spot on. With my current 10" wide rims they almost fit I knew it would be very tight. I will planned to drop down to a 9" wide rim to give me some more room.
The bad.......I failed to realize the position of the rear brake caliper on the rearend hits the frame. In this case it puts it right into the notch which limits how much I can lower it. The solutions for this...I will rotate the OE bracket and dust shield on the rearend and re-rill the mounting holes...This will move the caliper out of the notch. With all my work my rear runningboard is about 1 1/2" from laying out in the back. It seems as it the bags are holding it up. The bags wont collapse anymore. I will pull the bags out totally just to confirm that the bags are limiting it from laying out. The clearance in the body seems to have done the trick to create enough clearance for the wheel to go up into the body. One other thing that will help to fully layout is the tire size that I will go with for the 22's will be almost 1/2" shorter in diameter. Here are a few pics
#831 |
One more pic of just a wheel detail shot.
Marc
#832 |
Lookin' good
1950 3100 5 window |
#833 |
looks great. are you sure your caliper isn't holding you up and not the bag?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#834 |
![]() Join Date: Jul 2012
Marc I am glad the caliper rotation will fix the interference issue. Before I saw your solution my first thought was ..."Oh crap"... Looking good!
#835 | ||
Thank you
Marc
#836 |
Looks good, glad you have figured out a game plan to get it all to fit and layed out just right. Waiting to see!!
#837 |
Looks good!!
No doubt you fix the caliper issue!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#838 |
I like where this is going
#839 | |
Thanks, I'm gaining. I have the driver side pocket almost finish welded. I also have the metal cut for the passenger side. Fingers crossed but these wheel pockets that I created up in the body might just work. It is hard to explain but I have taken some pics that I will share once I get the final welding done. Thanks man, kind of figuring it out as I go... Marc
#840 |
Kees, I'm glad your so confident...ha ha
#841 |
![]() Join Date: May 2015
Just wondering Marc but if you had known about your caliper clearance issue could you have "clocked" the axle ends when you had it narrowed? To rotate the caliper
#842 |
Looks pretty nice! Are those wheels shown in the pics the 22's you are going to be using? Would 20's get you on the ground easier?
keep it going!
My Build: 57 Chevy Pro-Street |
#843 | ||
Marc
#844 |
So I have been out in the garage quite a bit lately. I have been concentrating on the rear wheel well area. If you remember I cut a some body structure out of the way to allow the tire to go up into the body to allow me to layout on 22" rims. After I cut enough of the wheelwell I reinforced the opening with new metal to add strength back. At some point I will treat with rust guard then seam sealer before I add raptor bed liner to the whole underside of the body and fenders.
Next I needed to clearance the top of the fender the same width of the pocket so that wheel would not be limited by the top of the fender when I laid out. I then reinforced the fender area I removed with round stock to help add strength back the new opening as well as creating a smooth fender edge. One challenge that identified itself during this process was when I removed the top of the fender it left me with a sizeable gap between the body and the fender. In this process I lost one bolt hole from the new fender pocket. I'm guessing this is why the gap seems to prominent. I personally hate fender welding. I like using strip caulk between the body and fenders. I did this on my 48. I needed to add some metal to the top of the fender to help close this gap. I was just trial fitting. I will go back and finish weld at some point.
#845 |
More pics to help explain my progress.
#846 |
A couple more..
I then mounted the wheels and bolted up the rear fender to push it out of the garage to take a better look. I wish I had less gap between the tire sidewall and the edge of the fender. Oh well I guess this in another compromise when running large wheels and trying to lay out. I cant push the wheels out father to the outside because the wheels need to tuck up inside the Suburban body when it airs out. Now I just need to do the same fender mods to the passenger side. Marc
#847 |
![]() Join Date: Mar 2011
Nice work Marc, looking good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#848 |
Great job - that looks awesome!
Scott ______________ my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979 |
#849 |
It looks fantastic!!
Really nice work!
#850 |
Thanks guys!!
Marc
| Bookmarks |
