Old 02-16-2017, 09:03 PM   #1126
65sub
65sub's Avatar
Re: Nik's 62 build
That motor mount certainly is an improvement. Keep checking things off the to do list and you'll be driving soon.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-18-2017, 01:35 PM   #1127
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
It sure is, thanks for the inspiration Dale!
Over the past couple days I've been getting the firewall finished up, putting in grommets and clips, organizing wiring etc. And just last night I had two buddy's over to give me a hand getting the motor in, as you can see below we had success!
62stepside longbox is offline   Reply With Quote
Old 02-18-2017, 01:38 PM   #1128
62stepside longbox
Re: Nik's 62 build
All I needed to do to get the motor in was attach my front motor mount perch to the crossmember, to my surprise when I mocked it up it lined up perfectly! So all I needed to do was weld it up. I also plan to drill holes through the crossmember and install some grade 8 bolts just to be safe.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 02-18-2017, 02:04 PM   #1129
Re: Nik's 62 build
Old 02-18-2017, 07:34 PM   #1130
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Old 02-18-2017, 08:25 PM   #1131
Advanced Design
Advanced Design's Avatar
Re: Nik's 62 build
Looks really good Nick. Nice work!
Advanced Design is offline   Reply With Quote
Old 02-18-2017, 11:07 PM   #1132
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Nik's 62 build
Looks good!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 02-19-2017, 02:47 AM   #1133
Grizz1963
Grizz1963's Avatar
Re: Nik's 62 build
Impressed and pleased as always.
Looking good.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-19-2017, 08:22 PM   #1134
62stepside longbox
Re: Nik's 62 build
Originally Posted by TJ's Chevy View Post
Thanks Doug!
Originally Posted by Classic v6 GMC's View Post
Looks good!!
Thanks!
Looking good.
Thanks rian!
Yesterday I went on a parts hunt again and came back with a few neat items I got from a 61 one ton cab, one of them was a choke cable assembly, here it is.
Old 02-19-2017, 08:23 PM   #1135
62stepside longbox
Re: Nik's 62 build
Here is the old one that needed replacing badly, some kind of aftermarket cable and knob that didn't fit correctly and was also broken
Old 02-19-2017, 08:26 PM   #1136
62stepside longbox
Re: Nik's 62 build
I installed it in the dash and ran the cable through a grommet in the firewall and hooked it up to the carb. Now all the dash knobs match. The yellow one below will not be staying.
Old 02-19-2017, 08:31 PM   #1137
62stepside longbox
Re: Nik's 62 build
And the other item I got from the 61 cab was this neat pair of chrome coat hooks that were attached to the upper corners of the cab behind the seat, not sure if they were an option or not but I thought they would look good in my truck. Chrome is pretty pitted so I'll probably just sand and paint them.
Old 02-19-2017, 08:34 PM   #1138
62stepside longbox
Re: Nik's 62 build
And this afternoon I spent a few hours bodyworking one of the inner fenders and got it sanded with 60 grit then 120, then 220 and sprayed one coat of rustoleum, sometime within the next week I'll put another coat on and get the other inner fender finished. This will allow me to start bolting all the front sheet metal on.
Old 02-20-2017, 02:16 AM   #1139
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Liking the progress man. Wish the weather was better for mine.
Old 02-20-2017, 02:46 AM   #1140
62stepside longbox
Re: Nik's 62 build
Thanks tj, unfortunately weather isn't good at all here, about 40 degrees and lots of rain. Still lots of snow on the ground as well. I just put on a jacket and a hat and I'm good to go
Old 02-22-2017, 09:44 PM   #1141
62stepside longbox
Re: Nik's 62 build
Didn't have too much time today but I got started on the dash extension project. I made a template from construction paper planning out where the four gauges will be located and decided how I wanted it to be shaped. Here it is taped up to the dash.
Old 02-22-2017, 09:56 PM   #1142
62stepside longbox
Re: Nik's 62 build
I cut a couple of pieces out and that's all I got done so far. I'll be continuing progress on this tomorrow
Old 02-23-2017, 01:17 AM   #1143
AJCK87
Re: Nik's 62 build
Hey Nik, man your really knocking it out of the park! Your making me feel lazy, working dispite the weather hahaha. That engine is sure looking good back where it belongs
AJCK87 is offline   Reply With Quote
Old 02-23-2017, 06:21 AM   #1144
Re: Nik's 62 build
Old 02-23-2017, 11:41 AM   #1145
RKS0069
RKS0069's Avatar
Re: Nik's 62 build
Looking really great! I've never seen a engine perch like that before, my V6 has the horseshoe mount but it bolted directly to the crossmember. I think it's amazing that you are making such good progress and spending very little money along the way. Keep it up! Can't wait to see you driving her down the road.
http://67-72chevytrucks.com/vboard/s...d.php?t=675881
1972 C-10 SWB
1962 3/4 ton LWB
2011 GMC Sierra LML Z71 crewcab shortbed
RKS0069 is offline   Reply With Quote
Old 02-23-2017, 12:17 PM   #1146
62stepside longbox
Re: Nik's 62 build
Thanks guys, I'm really trying to get the truck drivable before summer starts so a little bad weather isn't going to stop me!
Thanks, this mount used to be riveted to the old crossmember but I welded it on to the new crossmember, I also plan to put some grade 8 bolts through it as well just to be safe. As far as spending as little as possible, it's more so because I have to. I am not rich by any means
Old 02-23-2017, 01:01 PM   #1147
scoot_mcgrute
Re: Nik's 62 build
I know I've said this before but the your attention to detail and the quality of the build is awesome! I wish I had half the skills you did when I was your age, you're going to have one sweet little head turner of a pickup soon
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 02-23-2017, 11:06 PM   #1148
62stepside longbox
Re: Nik's 62 build
Thanks so much Scott, it's all about learning experiences. I have a feeling you're going to like what I'm unveiling right now.
Here is the gauge cluster almost finished up, I really took care keeping the gaps tight, the welds good and smoothing it out to a finish that is so good it won't even need a spot of filler. It's all made from just plain old flat 20 gauge sheet metal. I used a hole saw to make the holes for the gauges. Here is a front view of it.
Old 02-23-2017, 11:08 PM   #1149
62stepside longbox
Re: Nik's 62 build
Here's a good picture of the bottom, the weld seam is literally invisible.
Old 02-23-2017, 11:09 PM   #1150
62stepside longbox
Re: Nik's 62 build
Another shot of the bottom side
