Old 02-18-2017, 03:53 PM   #1
dmjlambert
dmjlambert's Avatar
Name that tool please, passenger head temp sensor plug
Hi
My 1969 Chevy 350 engine was rebuilt with newer heads. Head casting number 10147898 from 1995 crate engine. I am looking to add a temperature sensor on the passenger side, so I need to remove this plug. Can you tell me what tool to get? Some sort of a square drive tool. I tried inserting a socket wrench 1/4 drive and it is too little, 3/8 is too big. Is this something metric?
Old 02-18-2017, 03:56 PM   #2
kwmech
Re: Name that tool please, passenger head temp sensor plug
3/8'' ratchet extension hooked to a 1/2'' breaker bar. Sometimes a little bit of heat with it
Old 02-18-2017, 04:22 PM   #3
B. W.
B. W.'s Avatar
Snap-On P/N PPM410A 5/16" square drive socket or
PPM4110A 11/32" but a 3/8" fits the only old head I have around.
B. W. is offline   Reply With Quote
Old 02-18-2017, 04:45 PM   #4
dmjlambert
dmjlambert's Avatar
Thanks! I see on Snap-on's web site they are calling them pipe plug sockets. Now that I know what they are called I see sets of them are available in male and female, or internal and external as Snap-on calls them.
Of course I have an oddball size so I can't cheat with with a common ratchet extension. :-)
Old 02-18-2017, 04:47 PM   #5
B. W.
B. W.'s Avatar
Yeah, that's why I bought the set, don't use em much but when you need em you need em!
Old 02-18-2017, 05:20 PM   #6
truckster
truckster's Avatar
Or a cheap extension from Harbor Freight and a couple of minutes on the grinder...
Just be careful not to get the work piece to hot, or it will soften the temper.
truckster is online now   Reply With Quote
Old 02-18-2017, 08:03 PM   #7
davepl
davepl's Avatar
That's what I did. Cheaper than buying a set of square drive plugs that I'll never need and faster since I had a spare on hand!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-18-2017, 08:44 PM   #8
hamjet
hamjet's Avatar
x2, you may have to heat around the circumference to get it to break loose though. some of that aged pipe dope doesn't break loose too easily...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
plug, square drive, temperature sensor, tool
