Old 02-14-2017, 08:45 AM   #826
youngrodder
youngrodder's Avatar
Re: 53 Surburban "Family Truckster"
Originally Posted by mongocanfly View Post
Rear looking good marc..nice and clean
Originally Posted by oldman3 View Post
Looking good there Marc...Jim
Originally Posted by Scott2 View Post
Nice job - looks great! It'll be nice to see it back under the burb.
Originally Posted by Eagletucky View Post
Nice and clean!
Thanks guys, I'm slowly getting rid of my remaining rusted dirty parts. I look forward to the day I get to bolt this back together as clean painted parts.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is online now   Reply With Quote
Old 02-14-2017, 11:39 AM   #827
Flysocal
Nice work on the rear end. I took the easy route and bought a moser 9" for my truck project. But threads like this get my juices flowing. I have a 71 Camaro on deck and I'm thinking I will rebuild the stock rear end on that.
Flysocal is offline   Reply With Quote
Old 02-14-2017, 12:46 PM   #828
youngrodder
Yes, had I been able to use my stock axles I would have been money ahead. It really was not all that thought. I learned a lot. Sometimes the easy route is also the smart route...
Marc
Old 02-14-2017, 06:58 PM   #829
lower50's
lower50's's Avatar
That's one good lookin rear end
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-17-2017, 11:03 PM   #830
youngrodder
I put a little garage time today. I re-installed the rear end. It confirmed some things and identified some new challenges...Ok so for the good. It looks like my measurements to shorten the rearend were spot on. With my current 10" wide rims they almost fit I knew it would be very tight. I will planned to drop down to a 9" wide rim to give me some more room.
The bad.......I failed to realize the position of the rear brake caliper on the rearend hits the frame. In this case it puts it right into the notch which limits how much I can lower it. The solutions for this...I will rotate the OE bracket and dust shield on the rearend and re-rill the mounting holes...This will move the caliper out of the notch.
With all my work my rear runningboard is about 1 1/2" from laying out in the back. It seems as it the bags are holding it up. The bags wont collapse anymore. I will pull the bags out totally just to confirm that the bags are limiting it from laying out. The clearance in the body seems to have done the trick to create enough clearance for the wheel to go up into the body. One other thing that will help to fully layout is the tire size that I will go with for the 22's will be almost 1/2" shorter in diameter.
Here are a few pics
Old 02-17-2017, 11:05 PM   #831
youngrodder
One more pic of just a wheel detail shot.
Marc
Old 02-18-2017, 09:36 AM   #832
MIKESAD50
Lookin' good
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-18-2017, 10:03 AM   #833
99 to Life
99 to Life's Avatar
looks great. are you sure your caliper isn't holding you up and not the bag?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-18-2017, 07:42 PM   #834
Advanced Design
Advanced Design's Avatar
Marc I am glad the caliper rotation will fix the interference issue. Before I saw your solution my first thought was ..."Oh crap"... Looking good!
Advanced Design is offline   Reply With Quote
Old 02-19-2017, 09:54 PM   #835
youngrodder
Originally Posted by MIKESAD50 View Post
Lookin' good
Thank you
It was in the picture but I removed it and it still bottoms out on the bag.
Yes I'm hoping it is an easy fix. I will need to pull the rear end and take the axles out again....I spoke with Nate at Porterbuilt on Saturday and he is going to make me some new lower bag mounts to allow this to layout. He is determined to get this to layout the way I want it...His words...He is a stand up guy and has been very helpful through this whole build. I will have to cut the current ones off, so I will have to pull the rear end for that anyway..
Marc
Old 02-21-2017, 09:41 AM   #836
lower50's
lower50's's Avatar
Looks good, glad you have figured out a game plan to get it all to fit and layed out just right. Waiting to see!!
1951 MG TD
Old 02-21-2017, 03:35 PM   #837
RockinKees
RockinKees's Avatar
Looks good!!
No doubt you fix the caliper issue!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-21-2017, 05:22 PM   #838
Flysocal
I like where this is going
Old 02-21-2017, 10:45 PM   #839
youngrodder
Thanks, I'm gaining. I have the driver side pocket almost finish welded. I also have the metal cut for the passenger side. Fingers crossed but these wheel pockets that I created up in the body might just work. It is hard to explain but I have taken some pics that I will share once I get the final welding done.
Thanks man, kind of figuring it out as I go...
Marc
Old 02-21-2017, 10:47 PM   #840
youngrodder
Originally Posted by RockinKees View Post
Looks good!!
Kees, I'm glad your so confident...ha ha
Old 02-21-2017, 11:06 PM   #841
mongocanfly
mongocanfly's Avatar
Just wondering Marc but if you had known about your caliper clearance issue could you have "clocked" the axle ends when you had it narrowed? To rotate the caliper
Old 02-22-2017, 11:05 AM   #842
ptc
ptc's Avatar
Looks pretty nice! Are those wheels shown in the pics the 22's you are going to be using? Would 20's get you on the ground easier?
keep it going!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-22-2017, 03:59 PM   #843
youngrodder
Yes I could have (you know what they say about hindsight). By re-drilling the backing plates I can get it more precise because I would still be guessing and hoping the axles where clocked correctly and even from side to side
keep it going!
No these are 20's off of my 48 truck with 275/45/20 tires (29.75" diam). If I go with 22's I will drop the tire size down to 265/35/22 (29.44 dia). That will help the width of the tire fitting into the body and it will help with laying out as it's a smaller overall diameter.. A win - win of sorts.
Marc
Old 02-26-2017, 10:45 PM   #844
youngrodder
So I have been out in the garage quite a bit lately. I have been concentrating on the rear wheel well area. If you remember I cut a some body structure out of the way to allow the tire to go up into the body to allow me to layout on 22" rims. After I cut enough of the wheelwell I reinforced the opening with new metal to add strength back. At some point I will treat with rust guard then seam sealer before I add raptor bed liner to the whole underside of the body and fenders.
Next I needed to clearance the top of the fender the same width of the pocket so that wheel would not be limited by the top of the fender when I laid out. I then reinforced the fender area I removed with round stock to help add strength back the new opening as well as creating a smooth fender edge. One challenge that identified itself during this process was when I removed the top of the fender it left me with a sizeable gap between the body and the fender. In this process I lost one bolt hole from the new fender pocket. I'm guessing this is why the gap seems to prominent. I personally hate fender welding. I like using strip caulk between the body and fenders. I did this on my 48. I needed to add some metal to the top of the fender to help close this gap. I was just trial fitting. I will go back and finish weld at some point.
Old 02-26-2017, 10:49 PM   #845
youngrodder
More pics to help explain my progress.
Old 02-26-2017, 10:58 PM   #846
youngrodder
A couple more..
I then mounted the wheels and bolted up the rear fender to push it out of the garage to take a better look. I wish I had less gap between the tire sidewall and the edge of the fender. Oh well I guess this in another compromise when running large wheels and trying to lay out. I cant push the wheels out father to the outside because the wheels need to tuck up inside the Suburban body when it airs out.
Now I just need to do the same fender mods to the passenger side.
Marc
Old 02-26-2017, 11:59 PM   #847
oldman3
oldman3's Avatar
Nice work Marc, looking good...Jim
oldman3 is offline   Reply With Quote
Old 02-27-2017, 12:30 AM   #848
Scott2
Great job - that looks awesome!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 02-27-2017, 05:59 AM   #849
RockinKees
RockinKees's Avatar
It looks fantastic!!
Really nice work!
Cheers!! Kees.
Kool Guyz CC
Old 02-27-2017, 09:57 AM   #850
youngrodder
Really nice work!
Thanks guys!!
Marc
