Old 02-18-2017, 07:01 PM   #226
MIKESAD50
Re: Mike's 50
Last couple days have made a little progress.
Yesterday I finished cab windlace on around the passenger door, just need to trim the ends on both doors.
Earlier in the week upper radiator hose pieces all I think I will need. I'm waiting on some new hose cutting tools I ordered and then I will start working on hose.
Today I started to mock up mounting of my "electrical Center" under the seat.
Its made of 3/16 aluminum sheet, engine ECM, TCM, and Fuse/Relay center and Dakota Digital box are temporarily mounted with misc, screws. The chassis fuse panel will be mounted on this panel also, still need to mount it to the floor..
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-18-2017, 07:05 PM   #227
MIKESAD50
Re: Mike's 50
I also installed my windshield by myself and it wasn't terrible but its in and hopefully weather tight.My hands are really sore from Beating on the windshield and seal/outer molding, during install. took a couple hours. I still need to install inner garnish moldings and outer center molding.
I brought them home to clean them up alittle.
I also put on the inner fenders, well just because I feel like I'm making progress, not sure if I'll need to remove them for other front end installation.
1950 3100 5 window
Old 02-18-2017, 08:36 PM   #228
Advanced Design
Advanced Design's Avatar
Re: Mike's 50
Good progress. I like where you are heading with the electrical center under the seat.
Advanced Design is offline   Reply With Quote
Old 02-20-2017, 10:23 AM   #229
reaper71
reaper71's Avatar
Re: Mike's 50
Look's good Mike!
Where did you pick up the hose pieces from Really like those!!
Mark.
reaper71 is offline   Reply With Quote
Old 02-20-2017, 10:31 AM   #230
MIKESAD50
Re: Mike's 50
Mark,
I got the lower hose parts along with the aluminum 90* elbow from Vibrant Performance products thru Summit, the other 2 90* silicone hoses I got from HPS
http://www.hpsperformanceproducts.com/
1950 3100 5 window
Old 02-26-2017, 02:56 PM   #231
MIKESAD50
Re: Mike's 50
Well have not been to productive on truck this week/weekend. I mounted the Windshield inner Garnish molding. I'm not sure if it was originally chrome but it is what came with my truck they were not new. I like them, might not be good in the sun.
I also mounted my overflow tank, might be redoing it later not much clearance.
Not getting much done is pushing my soft "want to have road worthy" in April is slipping away
1950 3100 5 window
Old 02-26-2017, 03:01 PM   #232
MIKESAD50
Re: Mike's 50
forgot a couple of pictures
1950 3100 5 window
Old 02-26-2017, 03:36 PM   #233
Flysocal
Re: Mike's 50
Excellent wor. I like the radiator hose fix!
Flysocal is offline   Reply With Quote
Old 03-05-2017, 03:53 PM   #234
MIKESAD50
Re: Mike's 50
Got the coating on underside of front fenders and panels from radiator support to fender.
This should allow me to go ahead and bolt up front clip.
I rolled the bead on the Aluminum 90* elbow for upper radiator hose.
I also ordered and received -6 AN PTFE lined stainless braided Hose and fittings for my trans cooler.
I dropped off at a waterjet/laser cutter, to cut me some trans cooler mounting brackets should have those back and get my buddy to weld them for me.
1950 3100 5 window
Old 03-07-2017, 10:51 PM   #235
MIKESAD50
Re: Mike's 50
going back together.
1950 3100 5 window
Old 03-08-2017, 03:27 PM   #236
focusedontheprize
focusedontheprize's Avatar
Re: Mike's 50
Truck looks great. I really like the direction you went. Can't wait to see it on the road.
focusedontheprize is offline   Reply With Quote
Old 03-08-2017, 03:44 PM   #237
MIKESAD50
Re: Mike's 50
Thanks,I'm pretty happy with how it is coming out, other than taken forever.
1950 3100 5 window
Old 03-13-2017, 06:44 PM   #238
MIKESAD50
Re: Mike's 50
Not a lot of progress. this weekend I got 1 piece of Dynamat on roof, I also painted sprayed the front hood brace/latch pin. I bead blasted awhile back and just sprayed with a clear coat.
How important are the rods/braces in the front corners of the hood? I only have one of them and haven't reinstalled.
Still having the transcooler mounts made and when they are done I will post a picture.
Think my buddy will be coming over this coming weekend to align the front end and doors
1950 3100 5 window
Old 03-14-2017, 09:39 AM   #239
reaper71
reaper71's Avatar
Re: Mike's 50
Mike, The rod's on the fenders help with alignment of the fenders (pull them in) as well as keep them a little bit more stable.
That being said, Guy's do leave them out if your going with the Patina look and are not over concerned with the hood to fender line. Hope this helps
Mark.
Old 03-14-2017, 08:11 PM   #240
MIKESAD50
Re: Mike's 50
Here is the transmission oil cooler set up I plan to run. I plan to run it mounted to the outside of the frame just in front of the middle running board bracket on the right side. hopefully it will work ok. The fittings will be on top and come out just above the frame rail.
1950 3100 5 window
Old 03-14-2017, 09:11 PM   #241
Advanced Design
Re: Mike's 50
Your truck is really coming together. Looking good. That is a nice trans cooler set up.
Old 03-15-2017, 12:11 AM   #242
mongocanfly
mongocanfly's Avatar
Re: Mike's 50
That trans cooler is nice..who makes that ? any plans on a gravel guard for it? I know what would happen to me if it was mine and I mounted it there...
mongocanfly is online now   Reply With Quote
Old 03-15-2017, 09:33 AM   #243
MIKESAD50
Re: Mike's 50
The brand is Derale purchased from Summit.
I hadnt thought of gravel guard, I will think about that.
1950 3100 5 window
Old 03-17-2017, 03:58 PM   #244
MIKESAD50
Re: Mike's 50
Before drilling mounting holes in frame, you guys think the location of the cooler will be a problem? it is above the running board mount, I think I will be putting a drop down battery in front of it which I think will hang lower than the cooler.
effectiveness not sure of but cant change it up latter if not working properly.
1950 3100 5 window
Old 03-17-2017, 04:50 PM   #245
donandal
Re: Mike's 50
It's hard to find space for a cooler isn't it?
I think with a fan it will move the air just fine
where you have it.
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-19-2017, 03:02 PM   #246
MIKESAD50
Re: Mike's 50
Got it mounted. used 5/16-18 rivet nuts in the frame. I still need to finish the cooler lines and wire the fan.
I also got some more dyna mat installed.
1950 3100 5 window
Old 03-20-2017, 09:47 PM   #247
MIKESAD50
Re: Mike's 50
Just a couple pictures. Trans oil cooler lines. Fittings at Trans with Temp switch to control fan on cooler, Set for 180*
1950 3100 5 window
Old 04-01-2017, 05:13 PM   #248
MIKESAD50
Re: Mike's 50
Made alittle progress over the last week. Got Dynamat on Roof done other than tape, ordered more. Finished floor other than behind the seat riser and a bit of the back panel. Mounted the electrical panel under seat need a couple more mounts for the center of panel.
Started some wiring at the back to the fuel pump, fuel level sender and the rear light wiring. Will secure more later once I get the bed mounted
Wrapping with Painless power braid, I'm trying MagDaddy's for mounting harnesses. and just a picture of it with running board on.
1950 3100 5 window
Old 04-01-2017, 05:17 PM   #249
MIKESAD50
Re: Mike's 50
couple more
1950 3100 5 window
Old 04-01-2017, 06:45 PM   #250
Advanced Design
Re: Mike's 50
Looks really good Mike. I like the look of the powerbraid. It will be interesting to see how the magnetic clips work out for mounting the harness. Good progress!
