#16 | |
motor exploder
Re: Brake booster questions - need help!
All you 'should' need to do is change the pedal ratio/pivot from where the manual brake rod is attached to the pedal arm to the position where it would be for power brakes, then you'll probably have to whip up a pedal rod or adjuster to adapt to the booster. If I'm wrong on this, someone please correct me.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() Use the SEARCH function on this forum - it is your friend!! |
| Bookmarks |
| Tags |
| brake booster, cpp, drum brakes, power brakes |
