02-22-2017, 03:58 PM | #1 |
4.75 rotors on 71 up spindles?
Anyone know of a rotor that will go on the 71 and.spindles and uses 5x4.75 bolt circle? Want to go to car bolt pattern. Alot more wheel options available for that bolt pattern.
02-22-2017, 10:00 PM | #2 |
Re: 4.75 rotors on 71 up spindles?
Do you have 1" or 1 1/2" rotors ?
02-22-2017, 10:08 PM | #3 |
Will check tomorrow. Are what came with the Early Classic Enterprises kit. Uses 71 and up spindles is all I know.
02-22-2017, 10:43 PM | #4 |
They made two different size spindles for 1" rotors or 1 1/2"rotors
02-22-2017, 11:20 PM | #5 |
1LE rotors off 1990 camaro
02-23-2017, 01:51 AM | #6 |
60-66 Nut
02-23-2017, 05:48 AM | #7 |
67-72 parts collector,…
These only work with the 81-87 spindles for 1" rotors.
There are tons of wheels for the 5x5 truck pattern. I wouldn't switch to the car pattern. Not worth the cost.
02-23-2017, 09:04 AM | #8 |
