Old 02-23-2017, 01:47 PM   #1
StanleyRosiello
StanleyRosiello's Avatar
Manual Choke
Hey. Just bought a 1970 C10 about a week ago. By far the oldest vehicle I've ever driven. I had never used a manual choke before. Here's my question. The choke cable is connected to the exterior choke lever on the carb. From inside the cab it is extremely hard to pull the choke or release it. I usually just end up popping the hood and doing it with my hand. Any fixes?
StanleyRosiello is offline   Reply With Quote
Old 02-23-2017, 01:51 PM   #2
Orange67
Orange67's Avatar
Re: Manual Choke
You will probably need to use graphite lubricant on the cable itself. Welcome to the site, good to see another Utahn on here.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 02-23-2017, 01:52 PM   #3
davepl
davepl's Avatar
Re: Manual Choke
You might try removing the cable, holding it in a manner that it will gravity feed, and shooting WD40 down the cable and letting it soak.
In case you've never run a manual choke before, there are two steps (when cold):
1) Pull the choke all the way out
2) Turn key
3) As soon as it fires, you push it in about 1/2" or so, based on feel to where it runs the best
A carb does this automatically with a vacuum powered "choke pulloff", but you have to do it by hand. So it's not a set it and start, it's a set it, start, then reset it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-23-2017, 05:22 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Manual Choke
2) Turn key
You forgot a couple of steps:
1) Push accelerator pedal to the floor
2) Pull the choke knob all the way out
3) Let up on accelerator pedal
3) Turn key
4) As soon as it fires, you push it in about 1/2" or so, based on feel to where it runs the best
Pushing the accelerator pedal to the floor before pulling the choke knob out sets the high idle cam to keep the RPM up while the engine is warming up.
LockDoc
Leon
Old 02-23-2017, 02:43 PM   #5
geezer#99
geezer#99's Avatar
Re: Manual Choke
What carb?
Do you have pics of the choke on the carb?
Old 02-23-2017, 02:50 PM   #6
StanleyRosiello
Re: Manual Choke
Originally Posted by geezer#99 View Post
What carb?
I'm pretty sure it's edelbrock 1405 600 cfm. I'll post pics soon.
Old 02-23-2017, 03:00 PM   #7
toolboxchev
Re: Manual Choke
Have had that set up on my truck over 8 years, bought new, have not had an issue with it.
toolboxchev is offline   Reply With Quote
Old 02-23-2017, 03:10 PM   #8
StanleyRosiello
Re: Manual Choke
Can you post a pic of the hook up at the carb? Also how long is the choke cable. I think mine may be too long. There are no sharp bends in it but it is looped a little bit. Thinking about the wd40 method and maybe shortening it a little so there's less bends.
Old 03-02-2017, 04:19 PM   #9
StanleyRosiello
Re: Manual Choke
Hey sorry its been a couple days. Thanks for the replies. got the choke cable lubed up and rerouted and works perfect now.
