02-23-2017, 03:58 PM | #76 |
Re: 1966 C1434 SWB Custom Cab
Here are close ups of the two wheels.
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw |
02-26-2017, 08:35 AM | #77 |
Very nice !!!
06-23-2017, 09:34 AM | #78 |
Well stuff is falling out of the bed so out with the old wood so I'll be posting from time to time
06-23-2017, 09:38 AM | #79 |
For the true Chevy truck enthusiasts here is a picture of the original grease pencil marking on the brace at the end of the frame rails. It's is marked C1434
06-24-2017, 09:37 AM | #80 |
enjoying your build thread for the first time and will be checking back on progress. Really like the way you're doing things right as you go along. Had a very similar 66 swb bbw and do miss it! Looking forward to the progress.
07-07-2017, 12:49 PM | #81 |
Now that I'm back from the coast it's time to get back into the garage. Almost ready for some black paint. I'm hoping to get the bed back together this weekend. All the wood is cut to the proper width which is 6 3/8 at the corners, 7 7/16 starting at the wheel wells, and the two in the middle are 5 7/16.
Here's the link to GMC Paul's site for the wood info: http://www.gmcpauls.com/47-72_BedWood_Info.htm
My current 66 C-10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=641267 My dads 66 C-10 build Old Yellow http://67-72chevytrucks.com/vboard/s...42#post8543842 My You Tube channel: https://www.youtube.com/channel/UCm0...VItKbZ3jM5YEQw Last edited by CustomCab66; 07-07-2017 at 05:57 PM. |
07-08-2017, 06:59 PM | #82 |
Burning the midnight oil last night trying to get the boards painted so they could dry over night
07-08-2017, 07:01 PM | #83 |
Spent the better part of half a day installing the wood today but it was worth it.
07-15-2017, 08:23 AM | #84 |
That looks great!!!
09-03-2017, 07:53 AM | #85 |
Well I hate to part ways with my old SBC 400 but when it's time it's time. This managed to follow me home so now I preparing to drop this combo in there.
09-03-2017, 08:00 AM | #86 |
3/8 Fuel line added to the sender to feed the fuel pump through a 100 micron filter. The word on the web is to use a Walbro pump which seems to be inexpensive
09-03-2017, 08:14 AM | #87 |
In order for the lock up torque converter to function properly a constant 12 volt source needs to be wired to pin 33 on the PCM. The switch in the image is a corvette brake light switch which has normally open and normally closed contacts. I did change it up instead of using the jumper I ran an ignition hot ( pink wire) to the normally closed side of the switch while the button was depressed (foot off the brake peddle state).
09-03-2017, 08:38 PM | #88 |
I ran the fuel line today so that it exits the floor by the original line
09-04-2017, 02:43 PM | #89 |
So I guess you are using the old line to run the return line to?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
09-12-2017, 02:13 PM | #90 |
Yup. So the LS came with a 3/8 pressure line and a 5/16 return line. I have a Walbro inline fuel pump but I still need to get the fuel filters and misc fittings. To be continued
09-13-2017, 02:16 PM | #91 |
I really like what you are doing, mostly with the LS swap, and want to see the whole thing completed. The LS is my plan on my truck
09-13-2017, 02:51 PM | #92 |
But Found Her 25yrs Later!
I'll be watching from this point forward.
09-22-2017, 09:36 PM | #93 |
So out with the old. I'm interested in seeing what was causing #8 cyl to burn so much oil. It would foul a plug every 30 miles at highway speeds
09-22-2017, 09:39 PM | #94 |
Look at the build up on the exhaust valve. Is it 1/16 of an inch thick piston seems to be pretty clean considering how much oil it was burning.
09-23-2017, 01:43 PM | #95 |
So my garage floor is covered in SBC parts all of which are in excellent shape. The 882 cast heads are nothing special but because of the comp cams extreme energy cams .477/.480 lift I added comp springs, guide plates, and screw in ARP rocker studs. Next thing on my agenda is to pull the oil pan and pistons I want to see what #8 looks like
09-25-2017, 09:27 PM | #96 |
Number 8 piston was the one giving me trouble. But I found that the top ring gland on #3 had some damage from pre detonation or heat and the top ring was broken in three places. The engine has always had a weird noise on the rotating assembly. Maybe this was it
09-26-2017, 06:58 AM | #97 |
Did you pull the short block out already?
Bret
09-28-2017, 11:31 PM | #98 |
Not yet but getting close. Gonna drop the tranny first slide it out then work on removing the block. I do not have an engine hoist so it'll have to come out the bottom.
10-05-2017, 12:16 PM | #99 |
Attachment 1696118The whole front end is off hopefully will be able to stick the LS in place and finish the motor mounts.
10-05-2017, 06:24 PM | #100 |
So I set it in there and now it's a matter of figuring out the engine placement fore and aft so that I can drill the holes for the motor mounts. TO BE CONTINUED
