Old 02-24-2017, 12:08 AM   #1
61ShortboxDave
Can anyone tell me what my rearend came from?
I was able to read the following off the rearend in my 61.
3856525. GM3. HE1 14W
Can anyone tell me what this came from? It doesn't appear to be original to the truck.
Any help is appreciated.
Thanks for your time, Dave
61ShortboxDave is offline   Reply With Quote
Old 02-24-2017, 12:14 AM   #2
Softpatch
Softpatch's Avatar
Re: Can anyone tell me what my rearend came from?
Pictures would be really helpful in helping you identifie what type.
Should be a tag secured to a bolt on the front pumpkin
usually on the pass side
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 02-24-2017, 12:29 AM   #3
62stepside longbox
62stepside longbox's Avatar
If it looks like this then it's an eaton ho32, original for a 60-62 1/2 ton truck
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-24-2017, 12:37 AM   #4
Captainfab
60-66 Nut
he HE was used on both the '61 R10 and '65 C15. You need to determine whether you have a Eaton HO32 diff as shown above or a truck 12 bolt.
http://www.67-72chevytrucks.com/vboa...d.php?t=327764
Old 02-24-2017, 08:52 AM   #5
61ShortboxDave
Yes, it is a 12 bolt, not the Eaton.
Old 02-24-2017, 12:53 PM   #6
61ShortboxDave
Here's a couple of pic's.
Old 02-24-2017, 02:52 PM   #7
61ShortboxDave
I honestly had not hear of a C15 before.
So my 12 bolt is from the 65 C15 Truck?
Are there any rear disc conversion kits out there for these?
Thanks again.
Old 02-24-2017, 08:26 PM   #8
PGSigns
PGSigns's Avatar
I looks like 64 and up 12bolt for trailing arms. That is going by the track bar mount hole on the top right of the housing. Overall pics may help us till you what may have been to it during the swap into your truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-25-2017, 12:49 AM   #9
Captainfab
60-66 Nut
Yes. That housing was used from '65-'72. I make 5 different rear disc conversion brackets. Two for the 6 x 5.5" wheel stud pattern and three for the 5 x 5". There are links to the 5 x 5 for sale threads in my signature line. If you are interested in the 6 lug, let me know and I will send you links to those for sale threads. There just is not enough room in the signature area for all of my for sale threads.
Thanks again.
Old 02-25-2017, 10:15 AM   #10
KenAdams
KenAdams's Avatar
Thanks again.
There are some aftermarket options if you want to spend some $$. I used the Wilwood D154 Kit.
KenAdams is offline   Reply With Quote
Old 02-27-2017, 01:50 PM   #11
61ShortboxDave
Thanks very much for all the info !
Dave
Old 03-01-2017, 04:48 PM   #12
KenAdams
KenAdams's Avatar
Just finished putting my brakes on that same rear end today, only chose the Wilwood because the kit had a parking break.
