Old 02-23-2017, 11:10 PM   #1151
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
The backside
62stepside longbox is offline   Reply With Quote
Old 02-23-2017, 11:14 PM   #1152
62stepside longbox
Re: Nik's 62 build
And a front view.
I brought my tires to the school shop the other day and got them mounted, so I'll put up a pick of those tomorrow.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 02-24-2017, 01:41 AM   #1153
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Good job man, it'll look good in there.
Old 02-24-2017, 10:22 AM   #1154
65sub
65sub's Avatar
Re: Nik's 62 build
Nice job on the gauge panel. That really fits the look of the dash.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-24-2017, 10:31 AM   #1155
The1960APE
The1960APE's Avatar
Re: Nik's 62 build
The seatbelt tailgate latches are awesome, there is a guy here locally that did it on a 50's model....COOL IDEA!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 02-24-2017, 10:59 AM   #1156
scoot_mcgrute
Re: Nik's 62 build
That gauge pod is going to look great, nice work!
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 02-24-2017, 10:05 PM   #1157
62stepside longbox
Re: Nik's 62 build
Thanks tj!
Thanks Dale, thats what I was going for.
Thanks, I actually got the idea from a thread on these forums.
Thanks Scott!
Here are some pics of the tires mounted on the rims, I put the hubcap on just to get an idea of how it will look. I'm extremely happy about how good these look especially with the caps, the tires are not overly aggressive but they're still rough enough to get the job done
Old 02-24-2017, 10:07 PM   #1158
62stepside longbox
Re: Nik's 62 build
Another shot
Old 02-25-2017, 01:29 AM   #1159
Captainfab
60-66 Nut
Re: Nik's 62 build
Very nice work on the gauge pod
Old 02-25-2017, 08:50 AM   #1160
rusty76
rusty76's Avatar
Re: Nik's 62 build
I am digging the gouge pod as well. The tires and wheels look great. Cool.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-25-2017, 09:20 AM   #1161
Re: Nik's 62 build
Gauge pod and tires look good Nik!
Old 02-25-2017, 10:22 PM   #1162
62stepside longbox
Re: Nik's 62 build
Thanks John, means a lot coming from someone with your skill level
Thanks rusty!
Thanks bill!
Today was quite the busy day! I don't have any pictures to share at the moment but I got up early and spent some time sanding the other inner fender and got it prepared for paint and spayed the first coat of black on it and pulled out the other inner fender and put the second coat on it. I then spent the rest of the day replacing the timing belt on the family minivan, it all went smoothly. Tomorrow I'm hoping to get the the gauge pod mounted under the dash.
Old 02-27-2017, 03:11 AM   #1163
62stepside longbox
Re: Nik's 62 build
Temperatures dropped back down today and it started snowing unfortunately, but I still got some work done. I drilled a hole and installed a neat looking Chrome toggle switch into the gauge pod. Not entirely sure what I'll use it for yet, but I'm sure I'll find some use for it.
Old 02-27-2017, 03:12 AM   #1164
62stepside longbox
Re: Nik's 62 build
Mocked it up on the dash for the first time and started to make some brackets to mount it, that's as far as I got today. So far I'm really liking the way it flows with the humps in the dash
Old 02-27-2017, 02:16 PM   #1165
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Looks good man, we got some snow to. Was hoping to get some truck time in, but I ended up having to do some work on the GMC instead and then spent the rest of the weekend with my girl. haha
Old 02-27-2017, 02:46 PM   #1166
Ronzo
Ronzo's Avatar
Re: Nik's 62 build
*****in...
That really does flow well with the dash Nik, well done buddy.
Ronzo is offline   Reply With Quote
Old 02-27-2017, 04:48 PM   #1167
The1960APE
The1960APE's Avatar
Thumbs up Re: Nik's 62 build
Originally Posted by 62stepside longbox View Post
Here's a good picture of the bottom, the weld seam is literally invisible.
Your gauge pod and my A/C vent pod and brothers!!!
Old 02-27-2017, 07:52 PM   #1168
62stepside longbox
Re: Nik's 62 build
Thanks TJ, isn't that the way it always goes? Lol
Originally Posted by Ronzo View Post
*****in...
Thanks Ron!
Thanks! And you're right!
Old 03-01-2017, 10:31 PM   #1169
62stepside longbox
Re: Nik's 62 build
I got the one inner fender polished out and installed on the truck, the drivers side one still needs a second coat.
Old 03-01-2017, 10:35 PM   #1170
62stepside longbox
Re: Nik's 62 build
Since I switched to power brakes I had to make some space on the firewall, I did this by removing the windshield washer reservoir. So I needed to relocate it somewhere else in the engine bay. Here is what the stock bracket that mounts to the firewall looks like.
Old 03-01-2017, 10:36 PM   #1171
62stepside longbox
Re: Nik's 62 build
So I bent the tabs a bit different so I could mount it on the passengers side inner fender.
Old 03-01-2017, 10:41 PM   #1172
62stepside longbox
Re: Nik's 62 build
This is how it'll mount
Old 03-01-2017, 10:47 PM   #1173
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Makin progress!
Old 03-02-2017, 12:57 AM   #1174
Captainfab
60-66 Nut
Re: Nik's 62 build
The other stock location for the washer reservoir is on the drivers side of the radiator support above the horn relay.....just sayin'
Old 03-02-2017, 04:28 AM   #1175
Grizz1963
Grizz1963's Avatar
Re: Nik's 62 build
Good problem solving.
Inner fender looks good, in fact, you should be very proud of your build.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
