Old 02-25-2017, 12:37 AM   #1
Kinger615
Question Body alignment issue
My cab and bed body lines are not matching up. After installing new cab bushing it sets a lot higher the the bed. Is there any spacers or mounts that go under the bed to even this out? Did I buy or install cab bushings wrong?? The bed was off the truck when purchased so kind of frustrated in pointers would be greatly appreciated
Kinger615 is offline   Reply With Quote
Old 02-25-2017, 11:58 AM   #2
siggyfreud
siggyfreud's Avatar
Re: Body alignment issue
How far off are they? Could just be your new mounts aren't worn as much, or could be the wrong ones. Beds also have rubber spacers between the bed frame and body frame, so that could be missing as well.
siggyfreud is offline   Reply With Quote
Old 02-25-2017, 12:41 PM   #3
Kinger615
Thanks for the reply. It's probably a little over 1" difference between the two. I didn't know about the rubber spacers I see nothing on my truck
Old 02-25-2017, 01:16 PM   #4
siggyfreud
siggyfreud's Avatar
To be honest I'm not sure if all of them have them or use them. Mine have about 1/4" rubber spacers.
Old 02-25-2017, 01:16 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
This is after your torqued down the cab mount fasteners?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-25-2017, 02:04 PM   #6
Kinger615
They are tight but maybe they can go a little more. What ft lbs anyone know?
Old 02-25-2017, 05:26 PM   #7
vin63
vin63's Avatar
I torqued mine to 50 lbs.
Old 02-25-2017, 09:42 PM   #8
LT1 Burb
LT1 Burb's Avatar
Which is higher, the bed or cab. I had to shim my cab upto the bed, around an 1/8".
LT1 Burb is offline   Reply With Quote
Old 02-25-2017, 10:43 PM   #9
Kinger615
The cab is higher by a whole inch. Thinking I got the wrong body mounts they were given to me out of box when I bought the truck
Old 02-26-2017, 01:00 AM   #10
LT1 Burb
LT1 Burb's Avatar
Yeah, there is no way, you should see the height difference by fenders sloping towards core support. I would double check it against some other body mounts.
Old 02-26-2017, 02:30 AM   #11
vin63
vin63's Avatar
Just in case, this is the diagram of the cab mounts, shapes, and order they are installed:
