Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-28-2017, 02:03 AM   #4
James the III
Re: Delco 16009960 and aftermarket speakers
Originally Posted by HunterRotten View Post
Thanks for the information and it makes sense but how would wiring it like that affect the quality of sound? I know I shouldn't expect much from a stock HU but I'm curious.
Is there a way I can just use the headunit as just that and run an amplifier? What kind of amp would work with the stock HU or how do I make it work?
I'm doing this build with my dad and I'm learning from him but he is entirely clueless with audio and I am as well so this is a learning experience for us both.
Many g.m. cars/trucks owners replaced the speakers with aftermarket ones. with 4 ohms..
and the radios worked fine.. I'm sure if you had it blasting at close to full volume, for long periods ,it most likely over heat the amp chips..
So ,you can just run it..
Any amp with speaker level inputs will work with it if you go down that road..
if you want to use that same amp with the new head unit down the road..
get one with line level(rca) and speaker level inputs.
James the III is offline   Reply With Quote
