Old 03-01-2017, 12:34 PM   #26
redneckwheelman2
Re: Question about putting TBI in a 86 Chevy C10 305
Have you looked at howell performance? I just looked at there Tbi stuff they sell brand new harnesses for 350 bucks, i got my 8.1 swap harness and computer from them, everything is labeled very well and only took a afternoon to get it hooked up and positioned there instructions aren't terrible either, then all you would need to do is get one new coolant temp sensor for the computer a knock sensor, and o2 I have 1 or 2 spare Tbi distributors a stock computer from my 87 k20 and also a Tbi unit if you can't track the parts down locally, let me know
1987 v20 regular cab - work in progress swapped in a (1992 tbi 350 with vortec heads) old motor. currently has an 8.1l and 4l80 swap. flatbed bed 2 inch lift and 64 inch spring swap in the rear.
2002 chevy 2500hd extended long- blackbear tune. DD
redneckwheelman2 is offline   Reply With Quote
Old 03-01-2017, 01:28 PM   #27
patrickk1
Originally Posted by TechBill View Post
I had a mechanic tell me the other day to get a ATF oil and fill up all the cylinder with it then let it set for a week. He said if the rust is light and only surface, it will eat it away and the motor might be usable but he did said the intake will have to be dipped cleaned and I will need a replacement carb or go with a aftermarket TBI.
I bought a non-running bronco engine one time that had a "rebuilt" 351w engine in it. Once I started it up, i had 0 compression on 2 cylinders. Pulled the heads and saw stains on the cylinder walls (was not rough) indicating that water had gotten in there at some point. The valves on those two cylinders had started to rust not allowing them to close all the way. Had that 1 cylinder head rebuilt and all was good. That motor has 20k miles on it now and runs great. I would follow what the mechanic said and also check the condition of the valves.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
