Old 03-02-2017, 06:52 PM   #1
willy12844
Pulling radio out
I have a 72 c-10 and would like to replace the radio, and at the same time replace a broken lever in the heater/AC control. I see that I will ne to remove some of the flexible duck hoses, but do I need to remove the heater air flow unit that's against the inside of the firewall? Am I looking at a difficult patient challenging project here, or is it just time consuming? Any help or advice will be greatly appreciated.
The pessimist is one who feels bad when he feels good for,
fear he'll feel worse when he feels better
willy12844 is offline   Reply With Quote
Old 03-02-2017, 08:27 PM   #2
custom10nut
custom10nut's Avatar
Re: Pulling radio out
Time consuming for the most part. It'll be easier since you're removing the heater controls too.
No, you don't have to take out the ductwork, you just work around it.
If you have all the original brackets and brace up in there, there is a simple brace connected to the back of your radio to the dash next to the speaker opening.
custom10nut is offline   Reply With Quote
Old 03-02-2017, 08:31 PM   #3
randy500
I usually pull the radio through the glovebox. Makes it easy and you can see what your doing. The glovebox liner can be tough to remove without damage.
randy500 is offline   Reply With Quote
Old 03-02-2017, 08:49 PM   #4
davepl
davepl's Avatar
I'll second that. If you have time in advance, order a spare liner if it's a high end truck (very hard to do without crinkling the cardboard), and go through the glovebox.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
