03-01-2017, 02:03 PM | #1 |
4x4 leaf spring hangers ?
Hi everyone . I have what is supposed to be a 71 3/4ton 4x4 frame and the front leaf spring hanger for the rear leafs does not stick down from the frame very much . I didn't think much of it till I found a 70 4x4 in the junk yard to rob some other brackets from when I noticed those hangers stuck down farther with a stiffener on the back side . since then I have looked at a 71 3/4 ton 4x4 camper special that looks like even bigger hangers than the 70 . So just how many different types of hangers are out there and what do I actually have for a frame ?
03-01-2017, 02:06 PM | #2 | ||
"I ain't nobody, dork."
Re: 4x4 leaf spring hangers ?
Get the stamped VIN number off of the frame to decode it. Should be located near the power steering pump on top of the frame rail... or along the side of the frame rail under the drivers side door.
Gary
03-01-2017, 02:08 PM | #3 |
71 gmc k25
03-01-2017, 03:02 PM | #4 |
sub'd......and I would also ask this question in the 4x4 section of the forum
03-01-2017, 03:55 PM | #5 |
Hi guys I found some numbers SA6674 which is by the gearbox and 3941625 123 1 1848 under the door are of the frame . I took pics but they wont upload something to do with security token .
03-01-2017, 03:58 PM | #6 |
B.W. My hangers are about half that tall .
03-01-2017, 04:01 PM | #7 | ||
Your pics are probably too large and you also have to load them one at a time. Can't do multiple pics at the same time. You can load them all on the same post (up to 6)... just do them singularly.
Gary
03-01-2017, 04:01 PM | #8 |
The 2nd number you posted is a frame rail part number. ( Was it on the side of the frame rail ? ) the number your looking for would be on the top of the rail, you may need a mirror to see it if there's a cab on the frame. The other number would also be on the top around the steering box.
Pictures of the frame would also help.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
03-01-2017, 04:07 PM | #9 |
the only numbers by the steering box is the SA6674 number . no other numbers that I can find . its just a bare frame no cab
03-01-2017, 04:14 PM | #10 |
just tried only uploading 1 pic and same security token stuff . sorry I'm not much of a computer person
03-01-2017, 04:43 PM | #11 |
Just looked at my 70 Chevy K20, they are shorter than my GMC. Never noticed!
03-01-2017, 05:14 PM | #12 |
B.W. yes that is what I'm talking about . my supposed 71 frame has the same hangers as your 70 chev and the ones on the junk yard truck are like your 71 gmc . the one in the junk yard has a 69-70 grill in it but no glove box door and I never thought of writing down the firewall vin at the time .
03-01-2017, 05:16 PM | #13 |
B.W. seeing both your trucks are 3/4 tons maybe its a year thing ?
03-01-2017, 05:58 PM | #14 |
That's my guess, they're only a year apart, maybe it's a Chevy / GMC thing?
03-01-2017, 07:27 PM | #15 |
Quite possibly a year thing
Here's my sideways 71 3/4 ton chevy.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
03-01-2017, 08:01 PM | #16 |
I have a 1971 K20 Longbed It is for sure 3/4 ton and here is a quick video I made of the rear spring pearches. https://youtu.be/muMs3TgXxlM
03-02-2017, 11:20 PM | #17 |
I have both a 70 Chevy rear leaf spring 2wd with the short springs and a 71 3/4 4x4 with the long front rear springs. I would look to see if the frame has been sectioned or the front front spring was bolted on to a two wheel drive frame? I have never seen a true 4x4 with the shallow rear springs. Just my opinion though. Their are others with wayyy more expertise.
03-03-2017, 02:45 AM | #18 |
I will check mine and my sons trucks and see what they look like...
03-03-2017, 09:45 AM | #19 |
All about them K’s
My 72 has the long rear hangers
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
03-03-2017, 10:57 AM | #20 |
Roadtrip!
I think they were short trough 70 and tall after that. I don't think it mattered if it was 1/2 or 3/4 ton. I am not 100% on this...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-03-2017, 11:09 AM | #21 |
My 72 Chevy 1/2 ton has the long hangers.
03-03-2017, 11:10 AM | #22 |
