Old 03-03-2017, 10:33 AM   #1
just_ridin
Brake Booster working TOO much
Hey guys,
Finishing up a '71 Super Cheyenne and threw on a brake booster.
Unlike all the other threads I've found about this, I'm having the opposite problem. The brakes seem to get at full force with a minimum of effort, and the travel of the pedal is only about an inch to get that full force.
The wheels don't lock up, but it's concerning that they're so touchy and quick to grab that much.
Any thoughts? Thanks in advance.
just_ridin is offline   Reply With Quote
Old 03-03-2017, 11:36 AM   #2
bigrigpardo
Re: Brake Booster working TOO much
Did you adjust the booster so the rod that goes into the master is set right. Almost sounds like you have the rod length too long and it's already partially applying the brakes.
bigrigpardo is offline   Reply With Quote
Old 03-03-2017, 11:49 AM   #3
CUSTOM/10
CUSTOM/10's Avatar
X2
Exactly what I was thinking.
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is online now   Reply With Quote
Old 03-03-2017, 11:54 AM   #4
custom10nut
custom10nut's Avatar
X2 on Bigrig.
You need the power brake rod.
If I remember right, the manual is longer.
I did the same thing when I did the upgrade.
The first time I pressed the brake, I almost ate the steering wheel.
Just change out the rod and you're golden.
custom10nut is offline   Reply With Quote
Old 03-03-2017, 12:08 PM   #5
CUSTOM/10
CUSTOM/10's Avatar
Or adjust the rod ( Shorter ) if it's adjustable, mine was.
Originally Posted by custom10nut View Post
X2 on Bigrig.
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-03-2017, 12:59 PM   #6
just_ridin
Does this mean the pedal should be partially depressed when attached? The rod isn't long enough to attach when the pedal is up.
Old 03-03-2017, 01:27 PM   #7
just_ridin
Appreciate the heck out of the help, thanks.
I know it's always more fun when pics are involved...here are 2 before and 2 after...the patina on the hood was so gorgeous we fixed her up and did our best to re-paint the wear on the truck...a case of beer and 6 hours later we got her looking like this from rattle cans...took a mix of 3 colors, but got the match pretty darn close!
Old 03-03-2017, 01:33 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
Something doesn't sound right. There should be a pedal return spring that should pull the pedal back all the way against the rubber bumper under the steering column. The rod we are talking about you have to remove the master cylinder to access. It's between the master cylinder & the brake booster !
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-03-2017, 01:47 PM   #9
just_ridin
So there's one adjuster under the dash and another between the master cylinder and the brake booster if I'm understanding correctly?
I'm trying to translate here between the guy doing the work and here...thanks again for the input!
Old 03-03-2017, 01:59 PM   #10
CUSTOM/10
CUSTOM/10's Avatar
Yes, there are two places to possibly adjust .
If you had manual brakes and added a booster, and used the manual brake rod
( The one between the master cylinder & the booster ) the rod is most likely to long, and if it's adjustably it would need to be shortened, if it's not adjustable you may need to replace it with one from a power brake set-up.
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-03-2017, 02:20 PM   #11
CUSTOM/10
CUSTOM/10's Avatar
Here's a picture of the booster push rod I'm talking about. If it's to long your brakes could be dragging without even touching the pedal, or engage the brakes when you hardly even touch the pedal.
Gary
72 SWB 4x4
My 72 SWB Build
Old 03-03-2017, 02:59 PM   #12
just_ridin
It's the latter, engaging when you barely touch it.
Will get to it when I'm done with the day job and able to head over to the garage where we're working on it.
Again..lots of thanks.
I'm sure I'll be back with a few other questions down the road; next up is a C-20 we picked up, another '71 with 48k original miles...in great shape, or should I say shapes...it's largely disassembled.
I'll check back in if that's the issue, greatly appreciate y'all's time and effort to help out.
Old 03-03-2017, 03:15 PM   #13
Bigdav160
Bigdav160's Avatar
Did you use a master cylinder meant for power brakes?
IIRC, power brakes also have a different attachment point on the brake pedal
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-06-2017, 02:11 PM   #14
just_ridin
Wow....what a weekend.
So what happened...the booster was a used one we got with a mess of parts we accumulated from a build-gone-bad that the guy was just dumping everything he had for $1200...got a lot of good stuff, but the power steering pump had a hole in it and the brake booster...
the master cylinder was bad, and we did end up throwing the old manual one back on..mistake #1. Changed that out and it still wasn't working right, so step #2 was noticing the rod from the brake pedal was way off...removed that, redrilled the hole and installed again, only to realize that while it was working MUCH better, the pedal wasn't returning back up after letting off. After some hair pulling and head scratching we came to the realization that the spring in the booster wasn't acting right, so pulled another booster from the corner pile-o-parts and put that one in instead...it's a little slow on the spring-back, but the brakes aren't lagging/staying on, so i think we're in pretty good shape (whew).
Thanks for the input/advice/thoughts/help...very much appreciated!!
Old 03-06-2017, 11:48 PM   #15
Heavymetl
Yup, if you just tap the booster and it hits hard, and doesn't fully return its internal valving problems.
Glad you found the issue!
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 07-25-2017, 02:29 PM   #16
clos69
Its Topless Season!!!!
clos69's Avatar
Ok I have heard you can grind down the pushrod that comes out the BB into the MC to be able to make it work better....does anyone know about how much grinding is needed? thanks
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 07-25-2017, 02:57 PM   #17
randy500
With most things brake related grinding up to a 1/4" is good....
randy500 is offline   Reply With Quote
Old 07-25-2017, 04:12 PM   #18
Andy4639
Old member
Andy4639's Avatar
Wink Re: Brake Booster working TOO much
Just a note:
The brake pedal doesn't go all the way back to the rubber bumper and rest. There should be some gap but can't remember what it is.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-25-2017, 05:27 PM   #19
jeffahart
jeffahart's Avatar
You used the manual master. So it probably had the RPV for a drum setup and was holding pressure on the disc. Were the brakes still touchy after changing the master to a disc drum? I used a drum drum master for quite a while, just removed the Valve on the disc side of the master. I recently changed to disc disc master though.
White K20
jeffahart is offline   Reply With Quote
Old 07-25-2017, 06:15 PM   #20
jocko
jocko's Avatar
Glad you got it sorted out. One more thing that might be worth mentioning - I believe there are two separate clevis pin locations on the brake pedal lever itself (i.e. the bar connected to your actual brake pedal). I believe the UPPER one is for manual (provides more mechanical leverage to a manual system) and the lower for power (less mechanical leverage needed or desired when a booster is used).
Old 07-25-2017, 08:13 PM   #21
clos69
clos69's Avatar
I do not see another clevis pin location other than the original...If i try to drill another one lower im afraid my brake lights are going to stay on bcus the pedal will be moved down closer to the floor...can the brake light switch be adjusted if I do move it down?? Glad to see you are local Jocko...lol
-Carlos-
The of America
Old 07-25-2017, 08:38 PM   #22
jocko
jocko's Avatar
The switch can be adjusted by rotating the two nuts that clamp it in the metal opening. However, if you don't have another hole in the brake pedal rod to stick the clevis in, then I'm not sure I'd drill one. I should go look under my 72's dash - now that I think about it, this 2nd hole may have been a 60-66 thing... (the holes were about an inch apart on the pedal rod) Anyway, to answer your question - the switch is easily adjusted.
EDIT: pic of a brake light switch below (in a different bracket, but you get the idea) - not 2 nuts in this case, just a threaded shaft and one jam nut. Anyway - I went and checked both 72s in the barn, only a single hole. Sorry, I was thinking there were two, but that may have been my 66. I would not drill another one if there weren't two originally - should work without making a non-factory mod.
Old 07-25-2017, 08:55 PM   #23
mike16
Not sure but on some vehicles the diameter of the master cylinder piston is a different diameter on a disc brake set up vs. a drum set up.
made that mistake before, 15/16th dia. vs. 1 inch dia. makes a BIG difference and you feel it right away with a power booster
disc brakes usually have the larger diameter piston because disc brake calipers require a larger VOLUME of fluid to opperate
mike16 is offline   Reply With Quote
Old 07-25-2017, 11:22 PM   #24
clos69
clos69's Avatar
Thanks for all the great info guys... I forgot to mention my 71 was originally a manual disc brake setup and I added a booster.... Im leaning more on replacing the pushrod inside the booster with the original one that was attached to the brake pedal bcus Im still using the original MC....
-Carlos-
The of America
