Old 02-23-2017, 05:55 PM   #1
AASmedic
AASmedic's Avatar
Left over 72 Parts
1. Original 72 K20 engine wiring harness. It is all intact. The yellow coil wire was converted to adapt to an HEI but can easily be made to go back to a "points" connection. This is for a V8. $40 shipped. I also have a new plastic wire channel for this for an additional $5.
2. Original under dash wiring harness. This is also completely intact. This is for a truck with A/C and NO anti-dieseling relay.
$40 shipped.
3. Original jack hold down bracket/spring and bolts. Tool hold down spring included. $15 shipped. SOLD
4. Steering wheel with cap and hardware. I believe it is for a 79-81 truck. It was on my K20 when I bought it. Fit just fine. $55 shipped. SOLD
First "I'll take it" gets it.
Thanks for looking
My Paypal address is: http://paypal.me/KFerguson66
72 K20 Cheyenne Super
My "re-build" thread
http://67-72chevytrucks.com/vboard/s...?t=710221&goto
Thread for my Reproduction Jack Bags
http://67-72chevytrucks.com/vboard/s...d.php?t=715455
AASmedic is offline   Reply With Quote
Old 02-23-2017, 11:14 PM   #2
AASmedic
AASmedic's Avatar
Re: Left over 72 Parts
Open to offers
Old 02-24-2017, 02:10 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If the bolt used to mount the spring to the door jam will clean up like new, how about $12 shipped?
I figure it's the same bolt used for the end-bed tire carrier, and can use one............Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-24-2017, 02:53 AM   #4
AASmedic
AASmedic's Avatar
I will do $12. I'm not sure what you mean by clean up like new. Its in pretty good shape. No rust. I can try to buff off the paint if that's what you are looking for.
Old 02-24-2017, 12:58 PM   #5
71CHEVYSHORTBED402
No reason to do that thanks. If it's not stripped, pitted, or rusted out that works.
Tony
Old 02-26-2017, 02:48 AM   #6
AASmedic
AASmedic's Avatar
Jack hold down sold to Tony.
Old 02-26-2017, 02:50 AM   #7
AASmedic
AASmedic's Avatar
Ttt
Old 02-26-2017, 12:17 PM   #8
AASmedic
AASmedic's Avatar
No reasonable offer refused for the weekend.
Old 02-26-2017, 08:13 PM   #9
nawlinjoe
Do you happened to have a headlight wiring harness?
nawlinjoe is offline   Reply With Quote
Old 02-26-2017, 08:16 PM   #10
AASmedic
AASmedic's Avatar
No. No headlight harness. Sorry
Old 02-27-2017, 07:28 PM   #11
AASmedic
AASmedic's Avatar
Ttt
Old 03-03-2017, 07:30 AM   #12
AASmedic
AASmedic's Avatar
Bump for the weekend
Old 03-03-2017, 10:24 AM   #13
fatbass
fatbass's Avatar
I'll give $25 for the steering wheel.
fatbass is offline   Reply With Quote
Old 03-03-2017, 03:40 PM   #14
AASmedic
AASmedic's Avatar
I will do $25 if you pay shipping. If that works for you, I will get you a quote, just give me your zip code.
Old 03-03-2017, 10:00 PM   #15
fatbass
fatbass's Avatar
PM sent.
Old 03-04-2017, 01:40 PM   #16
fatbass
fatbass's Avatar
Payment sent. Thanks!
Will I need any adapters or will this work with my stock '71 non-tilt column and horn button? I can fab but I'd prefer not to.
Jim
Old 03-04-2017, 10:43 PM   #17
AASmedic
AASmedic's Avatar
THis should fit right on without adapters. It was on my stock 72 column.
Old 03-04-2017, 10:44 PM   #18
AASmedic
AASmedic's Avatar
Ttt for the weekend
Old 03-22-2017, 11:38 AM   #19
AASmedic
AASmedic's Avatar
Ttt
Old 09-01-2017, 01:02 AM   #20
AASmedic
AASmedic's Avatar
Ttt for the weekend
Old 09-01-2017, 04:36 PM   #21
crossjo
What's the best you would do on both wiring harness'. I don't really need them but put them up in case one day. Thanks!
crossjo is offline   Reply With Quote
Old 09-03-2017, 10:40 AM   #22
AASmedic
AASmedic's Avatar
Ij will do $60 for both if that works for you.
Old 09-09-2017, 12:50 AM   #23
AASmedic
AASmedic's Avatar
Ttt for the weekend. I'm open to offers.
