Old 01-02-2017, 05:37 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Disc brakes??????????'s
I am thinking about adding disc brakes to the front of the ramp truck.
Does anybody know if a later model truck disc brake system will work?
I ran across this on another forum and it's got me thinking!
1967 c20 disc brake change
I'm 99% sure that any 1971-91 8 lug 2WD C series (1987-91 R series) disc spindle will bolt right up. As for disc brake master cylinder/booster/proporti oning valve; I'd go with a 1971-72 setup.
Any and all help would be appreciated.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-02-2017, 09:00 PM   #2
wbc409
Re: Disc brakes??????????'s
From what I have found on this site, 71-87 C-20/30 would work. Most recommend swapping out the entire front cross member. I wouldn't mix and match brakes. I would use the master cylinder, proportioning valve that match the donor vehicle.
wbc409 is offline   Reply With Quote
Old 01-03-2017, 10:42 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Disc brakes??????????'s
Thanks that what I had plan to do is swap the whole front end over.
Old 01-03-2017, 09:15 PM   #4
hugger6933
Andy, That swap is just like the 1/2 ton stuff that has been swapped a ton of times from people coast to coast. It is just heavier trucks and heavier part but the idea is still the same. 73- 87 and up to 91 on some R and V series trucks [they didn't change body styles on the crew cab one ton and some dually trucks until 91.
hugger6933 is offline   Reply With Quote
Old 01-03-2017, 09:34 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Disc brakes??????????'s
Cool. I'll start looking for the parts then.
Old 03-04-2017, 07:33 PM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: Disc brakes??????????'s
After driving the Ramp truck today to Greenville SC I think the disc brakes are going to have to happen and soon!
I spent all afternoon Thursday and all day Friday on the drums but it's just not stopping like it should. The wheel cylinders are both leaking now on the front. I may have to fix the wheel cylinders for now but disc brakes are going on it at some point.
Question for anyone who knows. Has anybody tried late model stuff on one of these. I'm talking 2000 model stuff?
