Old 03-05-2017, 03:02 PM   #1
WannaBe68
WannaBe68's Avatar
No Way This Is Stock
I just replaced the window inner felt strip and outer rubber "seal"(?) strip. Since getting this ride I always thought the gap was huge, because of the original worn-out felt and outer rubber. With the new inner and outer installed the gap between the glass and the outer rubber seal is still huge!
Is there anything else that I can do to seal the window??
WannaBe68 is offline   Reply With Quote
Old 03-05-2017, 03:05 PM   #2
WannaBe68
WannaBe68's Avatar
Old 03-05-2017, 03:21 PM   #3
toolboxchev
Re: No Way This Is Stock
I have the same problem. If it is a 72 door the attempted to solve this problem by putting a screw in the door just below the vent window.
If anyone has some insight into a permanent solution I would like to know also.
toolboxchev is offline   Reply With Quote
Old 03-05-2017, 03:34 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
There is a metal strap that holds the two sides together. These are often broken and need tack welded back together. That's why they added the screw in 1972, to keep that from happening.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 03-05-2017, 04:18 PM   #5
notchbackgta
Before and after I changed mine, it was a pretty big gap too. I think the design is just bad
notchbackgta is offline   Reply With Quote
Old 03-05-2017, 04:44 PM   #6
El Dorado Jim
x2,there is no way of fixing your door without welding the strap and that will screw up your paint
El Dorado Jim is offline   Reply With Quote
Old 03-06-2017, 01:08 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I posted some pictures of the brace/bracket/strap inside the door in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=633866
LockDoc
Leon
Old 03-06-2017, 11:45 AM   #8
Hart_Rod
Hart_Rod's Avatar
The doors have a tendency to separate due to pulling on the door handle (poor design), try squeezing it back together.
Hart_Rod is offline   Reply With Quote
Old 03-06-2017, 04:04 PM   #9
HO455
HO455's Avatar
I was able to tack weld mine back up without damage to the paint. Mine was broken all the way where LockDoc's is only partially cracked. I taped the area off with duct tape and clamped the sides in position. By tacking one spot and then cooling it with a wet rag and slowly working from one end to the other I was able to repair the crack without causing any visible damage. Cleaned it, painted it and so far so good.
RIP Bob Parks.
Old 03-06-2017, 07:08 PM   #10
WannaBe68
WannaBe68's Avatar
Thanks Fellas' - Mine is a '69 and am I reading things right in that the brace/bracket/strap is only for a '72?
Thanks again -
Old 03-06-2017, 07:10 PM   #11
WannaBe68
WannaBe68's Avatar
So simple it just might work - I'll give it a go...thanks!
Old 03-06-2017, 09:08 PM   #12
HO455
HO455's Avatar
My 67 has the straps and I believe that all the rest of the years do. The difference on a 72 is they have a screw that goes through a dimple on the inside the of the door and threads into the speed nut on the outside part of the strap (you can see it in the photos LockDoc posted) thus pulling the two sides together. If I have to pull my wing window for some reason I will add the screw to mine. It won't have the correct dimple to countersink the screw but it won't have the gap either. I wish I had known about the screws earlier. GM must have too many problems and came up with the screw as a one year hold over solution till the square bodies came out next year
RIP Bob Parks.
Old 03-06-2017, 11:35 PM   #13
LockDoc
LockDoc's Avatar
Thanks again -
All '67-'72 Chevy and GMC truck doors have the support strap and like HO455 said only the '72's had the screw....
LockDoc
Leon
Old 03-07-2017, 12:24 AM   #14
70cst
70cst's Avatar
Per the rules ... please do not multiple post the same threads. Thanks
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-07-2017, 11:37 PM   #15
WannaBe68
WannaBe68's Avatar
No problem - sorry... Since it had to do with the doors/windows, which are the same on a Burb and Truck thought I'd get more feedback.
Won't happen again!
Old 03-07-2017, 11:45 PM   #16
pritch
pritch's Avatar
Would it be possible to add a screw (pre-'72) straight down thru the tabs instead of welding them? Or is it just as likely that one or the other has broken off the door instead of each other where they overlap? I'm sure I'll need to fix mine at some point soon.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 03-07-2017, 11:58 PM   #17
HO455
HO455's Avatar
Speaking from the experience I gained from the 3 doors on my Burban. Yes, if the spot welds had failed you could do that. However on mine, none of the spot welds had failed, the metal had cracked along the 90 degree bends. Basically the metal flexes at that point and over time it work hardens and then cracks.
RIP Bob Parks.
Old 03-08-2017, 12:21 AM   #18
chewychevy67
If you look at the 69 71 blazers they have factory pieces that cab be used on the trucks to support the doors. This is what they look like. The screw goes in the same spot as the 72 doors. This tightens the gap a bit.
chewychevy67 is offline   Reply With Quote
Old 03-20-2017, 06:29 PM   #19
notchbackgta
My straps are not broken and my "4th" door has this huge gap too, I thought this was about the 3/4th doors
Old 03-21-2017, 07:34 AM   #20
71BUCKET
Anyone have the measurement for what that gap is supposed to be at the strap and the rest of the channel. ?
71BUCKET is offline   Reply With Quote
Old 03-21-2017, 06:15 PM   #21
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Just learned something new about the trucks today. Now I know why the screw is just on the 72 doors.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-22-2017, 09:06 AM   #22
WannaBe68
WannaBe68's Avatar
I spent an evening the other day "squeezing" the inner and outer doors together and the gap has almost completely closed! Now when the window is rolled up the outer rubber seal actually seals against the window. I'm assuming this will happen again down the road, but what an easy fix.
Thanks again for the push in the right direction!
