Old 03-07-2017, 08:20 AM   #1
Jackogr
Dropped siphon tube into tank
Well, I finally got the old gas out of my 71 K5. As I was finishing up, I pulled the tube out of the tank and the small end pulled apart and fell into the tank. I shared some words with the pump (and myself for not being smarter than a $7 pump).
It's beyond reach in the neck, even after disconnecting fill tube directly at tank
Do I fret about this or just forget about it? It's a multi-use pump safe for fuel, so I don't believe it'll disintegrate. My fear is it could block the pump/send or maybe impact my ability to fill. I guess I could fill and find out, but what would YOU do?
I am making some progress
Jackogr is offline   Reply With Quote
Old 03-07-2017, 08:52 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Dropped siphon tube into tank
Roll the dice.......leave it in there.
Then if you have an issue....you can drop the tank.
Either way....you'll have to drop it...now or maybe later..... or maybe not....?
Be sure to put a filter in the line....that will catch any residue.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-07-2017, 12:15 PM   #3
Jackogr
Yup, I figure I'll leave it be and see. I picked up another pump and plan to sink a small piece of that pipe in gas in a glass jar to see if it breaks down at all. It was woth the $8 to me as it may inform next steps.
Old 03-07-2017, 02:56 PM   #4
codejitsu
I dropped one in my 41 Olds some 6 years ago and still haven't found it to cause an issue. You should be fine leaving it. But I may just be lucky?
codejitsu is offline   Reply With Quote
Old 03-07-2017, 04:43 PM   #5
Jackogr
Good to know I'm not the only one! I bet you had a few choice words yourself! This makes me hopeful--thanks for sharing.
