Old 03-06-2017, 10:14 AM   #1
buds56
buds56's Avatar
Question for the swapped crossmember trucks
I swapped an 87 C10 crossmember in my 61 project.
The 87 had a 305 and Ac in it when I pulled it
I have the engine, and a good portion of the frontend and accessories on it.
It sits a bit high, actually higher than it did with the torsion bar front.
My question is, are different springs being installed? cut a coil? to get to a normal ride height. Dropped spindles would get it down some.
buds56 is offline   Reply With Quote
Old 03-06-2017, 10:59 AM   #2
siggyfreud
siggyfreud's Avatar
Re: Question for the swapped crossmember trucks
When I swapped to an 85 front crossmember I used drop spindles, and reinstalled my 3 in drop springs that I had on the stock crossmember. Could your height differences be that the springs haven't settled, due to not having weight on them in awhile?
siggyfreud is offline   Reply With Quote
Old 03-06-2017, 12:30 PM   #3
PGSigns
PGSigns's Avatar
You are missing several 100 pounds off the front still and I would get it all together and drive it some before making changes. It will settle a good bit from where it is now
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-08-2017, 01:36 PM   #4
par4tom
The truck may settle some but I don't think it would be more then another inch from the photo. If you like the stock ride height, then leave it. If you want it lower so that the bottom of the fender opening is about level with the top of the tire, you will need to do a drop spindle.
Yes, you could cut the coil like we use to do in the old days before drop spindles, but why deteriorate the quality of the ride?
Nice truck!
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
