Old 03-08-2017, 11:30 PM   #1
ratfreak8871
Pinion set up help
Overtightened my pinion nut to 35in./lbs. Should I run it, replace it, or back it off to 25in./lbs, and run it???
ratfreak8871 is offline   Reply With Quote
Old 03-09-2017, 12:53 AM   #2
Dc42d76
Re: Pinion set up help
Pinion nut does not tighten to 24 inch lbs . 24-32 inch lbs is the force needed to turn the pinion after it is tightened. New crush sleeve ? Old crush sleeve ?
Dc42d76 is offline   Reply With Quote
Old 03-09-2017, 01:09 AM   #3
ratfreak8871
New sleeve bearings everything. Found spec on this all over the place anywhere from 12 - 29 in. Should I take it back to 35?
Old 03-09-2017, 02:09 AM   #4
ratfreak8871
Yes that's what I'm getting at,
Old 03-09-2017, 08:23 AM   #5
homemade87
Its not preferable to back off the pinion nut once you have gone to far . 35in lbs may be ok on a new bearing . If it is an old bearing I would start over for sure . But if new bearing I would back it off to 30in lbs and you should be fine . If you back it off to much the bearing will become loose and not have the proper pressure to keep it seated . If too much it will damage the bearing .
homemade87 is offline   Reply With Quote
Old 03-09-2017, 12:37 PM   #6
MikeB
MikeB's Avatar
New crush sleeves are cheap. You can also get a set of shims instead, which is what I plan to use next time. More user friendly and not affected by pinion nut torque. These are for 8.5" 10-bolt.
https://www.ringpinion.com/b2c/Produ...px?ProdID=8280
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-15-2017, 07:19 PM   #7
Port&PolishMan
Port&PolishMan's Avatar
Lightbulb Re: Pinion set up help
Dam'd If Ya _Do and Dam'd If ya Don't ? __ _ WTH
OK - Next Up - what the H are these Guys doing - First Video . .
https://youtu.be/OwrH2kBoyhw
Second Video - I able to Actually Follow what this Guy is Doing . .
Learn How to &^&%$&$ Communicate . .
Port&PolishMan is offline   Reply With Quote
Old 05-16-2017, 07:15 AM   #8
homemade87
Both the links to the videos are of the same video . But what he is doing is torquing the nut to crush the sleeve . Video is not complete info at all . Once the slack is out and the bearings start to seat is when you get preload . At this point you measure for drag and sneak up on it . Video stops short of this .
