Closed Thread
Old 03-11-2017, 03:00 AM   #5076
Clint72
Re: What did you do to your truck today? Chapter II
Today I undid the PO wired open choke job (choke still isn't in working order, need a pull off valve), and tried to figure out why my temp gauge isn't working, so pulled the instrument panel and found some cut and spliced wires.
Just bought the rig about 2 weeks ago, so have been doing what I can daily to get it un-rigged and daily drivable.
Clint72 is offline
Old 03-11-2017, 08:34 AM   #5077
hamjet
hamjet's Avatar
Not this morning but yesterday I put my air/heater control assembly back on after removing it because the control section separated from the face plate. (common problem).. I used JB weld to hold it together, seems to hold, we'll see how long it lasts. the other problem was the heater fan would not work. first thing I checked was the ground wire on the blower motor. sure enough, BAD GROUND... all is well in my universe once again....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 03-11-2017, 11:05 AM   #5078
74baggedbug
Replaced the cab and core support mounts and then took it for a spin.. after 5yrs I can see the light at the end of the tunnel
74baggedbug is offline
Old 03-11-2017, 03:23 PM   #5079
supercheyenne
Man I love the looks of what I can see!
supercheyenne is offline
Old 03-11-2017, 03:32 PM   #5080
mud.man.rj
mud.man.rj's Avatar
Beautiful hidden gem that roof, truly special..
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 03-11-2017, 03:47 PM   #5081
Nomadicflyer
Nomadicflyer's Avatar
That bed looks amazing!
All I can say is I'm a full tilt geek, when it comes to cable routing and such. Here's the block heater I installed, today. Took me an hour to figure out and fab up a way to get the wire away from the exhaust manifold above and the Y pipe below. Geek.
Next up; replace the master cylinder, shocks, start on the engine wiring and alternator. Hoping to put the fenders on, tomorrow.
1972 C20 Fleetside "Miss Olive"
http://67-72chevytrucks.com/vboard/s...d.php?t=721563
Nomadicflyer is offline
Old 03-11-2017, 03:56 PM   #5082
Nomadicflyer
HAMJET: I'm with you. I hate the grounding issues. While doing some work in the cab, I decided to hit the grounding issues with full redneck vengeance. This was my answer to grounding problems.... install a grounding bar that reaches forward to the engine and frame to bring all the grounds together. It's hidden under the steering wheel mount, and another one up front for the engine stuff. Jeez.
I ground down a sanding disc and anvil, put a sheetmetal screw up the center, and use it to clean the metal around ground attach points. After the ground is installed, I'll paint it. SoooOOOO don't want to mess with grounding issues!
Old 03-11-2017, 03:59 PM   #5083
Nomadicflyer
Grounding sander
Old 03-11-2017, 04:38 PM   #5084
RodnRudy
RodnRudy's Avatar
I installed my repop sport mirrors. Side view from the driver side is great but you've got to crane your neck to get a view out of the passenger one. One of those little convex stick on mirrors should help.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 03-11-2017, 05:13 PM   #5085
kilrcady
Originally Posted by Nomadicflyer View Post
Grounding sander
Brilliant!
kilrcady is offline
Old 03-11-2017, 06:45 PM   #5086
NoStopN
NoStopN's Avatar
The weather scared me from doing any work on the bed of mine. So, I just drove it around town.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 03-11-2017, 07:18 PM   #5087
66clow
66clow's Avatar
Got my new tags. Big thanks to Boostedc10, he donated to my cause with some good hinges. Didn't realize the hood is suppose to close so easy. Good people on this site! No longer have to do the dance and push the back of my hood down every time. Installed a cross bar to hold down my bed wood in the rear.
66clow is offline
Old 03-11-2017, 08:10 PM   #5088
iriereggaeman
iriereggaeman's Avatar
I had the same problem with those mirrors...passenger side is pretty worthless. It made me want to get a huge convex mirror to cover the whole surface!
iriereggaeman is offline
Old 03-12-2017, 10:30 AM   #5089
kilrcady
I made a little wedge piece out of wood and when I get a chance will have one machined out of aluminum.works great
kilrcady is offline
Old 03-12-2017, 11:00 AM   #5090
Boog
laying low
Boog's Avatar
Iriereggaeman
There are quite a few threads here about the mirrors. Something you might not have known is the passenger side mirror mounts further back than the left.
http://67-72chevytrucks.com/vboard/s...acement&page=2
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 03-12-2017, 11:18 AM   #5091
Econman
Econman's Avatar
Cab interior is painted!
The doors are almost finished out and ready to be painted and hung. 😁
Econman is offline
Old 03-12-2017, 12:13 PM   #5092
iriereggaeman
Thanks kilrcady and Boog. The PO installed the mirrors, so the holes are there already. I could measure to see if they are the same distance back on the passenger and drivers side, but it's unlikely I'm going to drill new holes. I'll give the wood shim a shot.
Old 03-12-2017, 07:55 PM   #5093
kilrcady
I went 3/4" to nothing wedge
kilrcady is offline
Old 03-12-2017, 07:56 PM   #5094
kilrcady
Funny have to replace my drivers mirror.POS smashed it.I ave to review security video
kilrcady is offline
Old 03-13-2017, 02:41 PM   #5095
tdangle
tdangle's Avatar
When I bought my sport mirrors, I got the set that has the passenger side a convex mirror in it. The actually work pretty well. I like the look way better than the stock west coast type mirrors the truck came with. I will admit they would not be good for towing or if you had a bed shell on. I figure if I'm towing anything I just buy a set of temp mount tow mirrors.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 03-13-2017, 04:44 PM   #5096
BugzC10
BugzC10's Avatar
Added emblem to spinners.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 03-13-2017, 07:41 PM   #5097
Toms67
Toms67's Avatar
Scraped off a couple pounds of crud. Rust free with all the Grease on it. LOL. Cleaned up pretty good. Got it painted and installed. Had to drill new holes. I have my motor mounted in the forward holes. I don't know if that is why or not. It's a Muncie m21. Maybe that's why.
Toms67 is offline
Old 03-13-2017, 09:28 PM   #5098
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Hey I did the same!
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline
Old 03-13-2017, 10:42 PM   #5099
Nomadicflyer
Wow, Econman! That looks amazing! You must be completely AMPED!
I put shocks on, fabbed a brake line on the back axle.
Old 03-13-2017, 10:59 PM   #5100
Econman
Econman's Avatar
I told my paint man that I wouldn't pressure him and it's true there was much to fix. But it's been exactly a year ON THE CAB. He promises to have it painted and complete with doors hung by the end of this month. We'll see...
Econman is offline
Closed Thread
