Re: Rear tank but original filler
If you try to route a hose all the way from the stock filler to the rear tank you will run into the problem of our trucks having lots of frame flex. If you're driving your truck on a bumpy road and look back at your bed you will find that it moves side to side a lot more than the cab. Even if you do use flexible rubber hose for the bed to cab connection I would still be worried about it getting cut or torn from the bed moving so much, this flex is the reason our trucks could never be unibodys. I would say just find a more era correct cap for the rear tank and be done with it.
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
| Bookmarks |
| Tags |
| filler, ideas, tank relocation |
