Old 11-04-2011, 06:23 PM   #1
LUNATICS
LUNATICS's Avatar
Wide tires
What is the widest rim and tire combo i can put on back of 64 c10 without narrowing rearend?
LUNATICS is offline   Reply With Quote
Old 11-04-2011, 06:34 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Wide tires
Fleetside... assuming you have stock rear axle...8x15 275x15 or 10x15 if you roll the inside fender bead.....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-04-2011, 07:08 PM   #3
LUNATICS
LUNATICS's Avatar
Re: Wide tires
thanks for the reply...yes stock width axle shortbed fleetside..i have taken measurements and think its possible to run 12 wide rim with 325/50/15 tires but not sure of backspacing..do you or anyone else know?..also its a 64 assuming the rearend was never swapped for another year..also some pics from anyone would be helpful...thanks
Old 11-05-2011, 01:21 AM   #4
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Wide tires
Moved the thread plus a bump to the top.
Alan's Classic is offline   Reply With Quote
Old 11-05-2011, 01:56 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wide tires
I have a tubbed stepside, but your fleetside may actually have a bit more room on the outside. 15x12 with a 325/50/15 et street. The backspacing is at 8.5"
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-05-2011, 02:33 AM   #6
Rich 5150 69
Re: Wide tires
http://67-72chevytrucks.com/vboard/s...d.php?t=443520
A couple more threads on this
Old 11-05-2011, 12:12 PM   #7
LUNATICS
LUNATICS's Avatar
Re: Wide tires
Br3w city...thanks for the pics and info...i wasnt exactly sure on b.s. If 7.5 or 8 or 8.5 would work but now i see...thanks alot
Old 11-05-2011, 01:05 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Wide tires
Most rim shops don't like backspace that large, you usually have to ask, but I have seen them up to 9.5" of BS. That would be nuts to me. 8.5 is really pushing it, and (at least with a steel sectioned wheel) narrows the center of the barrel, so brake clearance become very tight. A big part of fitment is the tire choice, if you want to run a non-radial, you might want a bit more clearance. The ET street radials I run have surprisingly little "bow" out under the weight of the truck. I have about 1/2" or so on the outside, and could roll the fender a bit if I needed to.
If you want to go that big, you HAVE to remove the e-brake cable from the drum. It interferes with the rim
Old 11-05-2011, 01:23 PM   #9
LUNATICS
LUNATICS's Avatar
Re: Wide tires
thanks for the info... i have found some wheels from centerline and weld with b.s. that will work but of course in 5 lug which i plan to swap axles from early classic enter. later on..i ran the mt et drags on a mustang i had and they did ok, but for the truck i was looking at bfg drags for it and yes they do balloon a bit more though and my e-brake cable is already removed...i guess i really need to take more pricise measurements and research my tire options a bit more...just wanting a good looking wheel and need that traction width!
Old 11-05-2011, 02:20 PM   #10
62 Longbed
62 Longbed's Avatar
Re: Wide tires
I'm running the stock truck rallys 15x8 with 305-50r-15's on back without any problems .. Once they are wore out I will be switching to the 275-60r15 tires ..
62 Longbed is offline   Reply With Quote
Old 11-07-2011, 02:28 PM   #11
NCD1966
NCD1966's Avatar
Re: Wide tires
thanks for posting, i was looking at running the same size tire on my stepper
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 11-07-2011, 04:29 PM   #12
jason65
Registerd User
jason65's Avatar
Re: Wide tires
I'm running 15"x8" with 4" backspacing and my wheels are perfectly centerd with about an inch on eather side. P235/75/R15 tires.
jason65 is offline   Reply With Quote
Old 03-11-2017, 05:11 PM   #13
1ss4me68
Re: Wide tires
1ss4me68 is offline   Reply With Quote
Old 03-12-2017, 11:37 AM   #14
contagious102
contagious102's Avatar
Re: Wide tires
Cut the rear end 4" on each side and installed new ,Moser axle's. These are 15"wide mickeys Thompson's tires on a 15 x12 rim with a 6.5 back space. Did cut the bed and use fleet side tubes in the bed.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
