![]() Join Date: Apr 2001
WTB Dual Battery harness
Could be a question for gmachines, but Im looking to upgrade my new to me 85 k2500 burb to a 12V dual Battery set up since, unfortunately, its a winter warrior. So didnt know if any of you guys knew a source, or had, a factory dual battery harness available. I allready have the aux. tray, so just need the harness. Thanks in advance!
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Re: WTB Dual Battery harness
lol....you know I've got ya covered! PM me for details....for example: running an isolator? doing an alternator upgrade?
On my 87 Diesel the only 'dual' portion is the 4ga positive cable that runs from drivers battery across core support to passenger side battery, a starter cable end at the battery designed for the dual cable, and the 4ga ground from the drivers battery to the AC/PS bracket. Everything else is the same as a regular vehicle. The 85A alternator has a 10ga output wire, but wires just like a gasser.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Ok....let me put together a kit that will show you a better idea of what I offer-I recently built one for my own truck-pics are always better than words!!
Subbed for pics.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Diesel and gas trucks are wired differently. The diesel trucks use both batteries to start which is why the cables run between each battery. The gas truck dual batteries are isolated from each other via a solenoid on the driver fender and get power from the distribution block behind the brake booster.
In for pics of said harness
"DON'T TOUCH THE TRIM!!"-Early Kyler |
Yeah I think in my application the diesel harness is the way to go... at -44 below I need both batteries with a carb
![]() Mike
Pic's harness's would be kool. Where this private pic's or just for got
to post here?
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
