Old 03-12-2017, 08:05 PM   #1201
62stepside longbox
62stepside longbox's Avatar
Re: Nik's 62 build
Originally Posted by TJ's Chevy View Post
Air horn!
Oh yeah!!
Get out of the way, a Chevy Truck is coming horn!!!
Everyone in town will know it's me comin! Even more so since I'll be running the other two factory horns as well, so hopefully 3 horns is enough
Today I worked on separating the grille, grille support and rad support.
62stepside longbox is offline   Reply With Quote
Old 03-12-2017, 08:06 PM   #1202
62stepside longbox
Re: Nik's 62 build
Here's some of the rust I'll be dealing with, not at all bad compared to how the rest of the truck was.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 03-12-2017, 08:59 PM   #1203
65sub
65sub's Avatar
Re: Nik's 62 build
Shouldn't be a problem for you Nik.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 03-13-2017, 08:27 PM   #1204
62stepside longbox
Re: Nik's 62 build
Not at all! This has pretty much become the routine
Today I got a little time in the garage so I started cutting! Always seems like I find more rust once I go deeper, this was no exception. But it's nothing compared to what I've done in the past so it shouldn't at all be a problem. I'll start on making some patches tomorrow.
Old 03-14-2017, 09:15 PM   #1205
62stepside longbox
Re: Nik's 62 build
After school I spent a couple hours on doing the rust repair first I welded this patch in place and smoothed it out.
Old 03-14-2017, 09:18 PM   #1206
62stepside longbox
Re: Nik's 62 build
Here is the finished product, the area where the bolt goes through to the frame was was triple layered 18 gauge, so that took a while to form.
Old 03-14-2017, 09:20 PM   #1207
62stepside longbox
Re: Nik's 62 build
Another pic, the next order of business is to sand and clean up the entire thing and then spray it black so it will be ready to install.
Old 03-16-2017, 11:59 PM   #1208
62stepside longbox
Re: Nik's 62 build
Got a little freetime today so I got the core support all cleaned up and painted, turned out pretty good. Tomorrow is the last day before spring vacation in my school district, the next two weeks I'll have off so I'll be getting some major things done on the truck
Old 03-17-2017, 12:50 AM   #1209
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Wish I could get two weeks off......from Anything at this point. lol! That much truck time would be sweet.....enjoy it man!
Old 03-17-2017, 09:06 AM   #1210
65sub
65sub's Avatar
Re: Nik's 62 build
Two solid weeks of truck time You should get a ton of work done. You'll be cruising in no time.
Dale
Old 03-17-2017, 07:56 PM   #1211
62stepside longbox
Re: Nik's 62 build
Thanks guys, it will be nice to have some time so I can get quite a bit knocked out all at once, of course I'll be doing lots of fishing as well
Today I got the core support bolted in and ran a few wires as well as cleaning up and attaching the horn relay and voltage regulator. Starting to look like a truck again!
Old 03-19-2017, 05:02 PM   #1212
62stepside longbox
Re: Nik's 62 build
I had been trying for a while without success to figure out some sort of mounting for the dash extension. I finally built some brackets that worked and mounted it up on the dash, the next step is to remove all the gauges and paint it.
Old 03-19-2017, 05:11 PM   #1213
62stepside longbox
Re: Nik's 62 build
Also been working on some of the smaller details, just today I got the battery tray cleaned, painted and installed plus I put in a new battery, and cleaned, painted and installed the voltage regulator and horn relay and both the factory horns.
Old 03-19-2017, 05:12 PM   #1214
62stepside longbox
Re: Nik's 62 build
And now it finally has a face!
Old 03-19-2017, 06:45 PM   #1215
72cs20
Re: Nik's 62 build
Excellent progress! Getting the front end back on is a real milestone.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 03-19-2017, 07:05 PM   #1216
Re: Nik's 62 build
Old 03-19-2017, 11:19 PM   #1217
62stepside longbox
Re: Nik's 62 build
Thank you, yes the front end is where the majority of the work is, once it's all finished it'll be a weight off my back.
Well today was quite the day! Along with the above progress I also worked into the evening and managed to remove the rear end, it just didn't want to let go! The u-bolts had to be cut off. But other than that it all went smoothly.
Old 03-20-2017, 07:53 PM   #1218
65sub
65sub's Avatar
Re: Nik's 62 build
Looking good Nik. Keep at it, spring's coming
Dale
Old 03-20-2017, 10:52 PM   #1219
62stepside longbox
Re: Nik's 62 build
Thanks dale, I'm not super tight on the plan, as long as I get it on the road before summer starts I'll be fine.
Today I made some more progress on the rear end swap, I knew I had to figure out some way to hook up an e-brake since the cables from the 71 rear end mounted to the trailing arms differently and were too short. But to my surprise when I pulled the cables from the backing plates and compared them I found out they would swap over and snap right in, no modifications at all!
Old 03-21-2017, 10:46 PM   #1220
62stepside longbox
Re: Nik's 62 build
Been struggling to get the u bolts out of the trailing arms, they are rusted right in. I've already tried heating up, soaking in penatrant oil and beating the crap out of them with a punch and sledgehammer and it didn't budge. I'm thinking I might have to take off my trailing arms and get the u bolts pressed out. Anyone have any other ideas?
Old 03-21-2017, 10:58 PM   #1221
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Nik's 62 build
I had the same problem on our 60. I just beat kept beating on them up and down and spraying with oil until they finally came out.
Have you tried tightening the nuts on the bolts? Might be able to spin them some.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-22-2017, 01:33 AM   #1222
62stepside longbox
Re: Nik's 62 build
I tried to turn it using a socket and breaker bar with a 4' pole on it, just felt like the breaker bar was going to bend with all the force I was applying. Tomorrow I'm going to try using an air hammer.
Old 03-22-2017, 10:35 AM   #1223
TJ's Chevy
TJ's Chevy's Avatar
Re: Nik's 62 build
Took me awhile to, I used a LOT of heat and a big hammer with a punch. Wasn't long after that. lol When I put the new ones in I coated them with anti seize.
Old 03-22-2017, 08:46 PM   #1224
62stepside longbox
Re: Nik's 62 build
That's what I've tried but with no such luck, good tip there on the anti-seize.
Today I tried the air hammer and that did the trick, I got both of them out on the drivers side, now I just need to finish the passengers side.
Old 03-23-2017, 07:03 PM   #1225
65sub
65sub's Avatar
Re: Nik's 62 build
That's the way Nik Just keep beating on it until it gives up
Dale
