![]() Join Date: Jan 2014
I screwed up and lost my wiper motor hardware
I'm usually pretty good at keeping track of everything but for some reason I cannot find my Wiper Motor hardware. Does anyone know what size the bolts are that hold the motor in and then what is the hardware that holds the arms on? Thanks a mucho.
Hey man ![]() 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
Re: I screwed up and lost my wiper motor hardware
there isn't a nut on the end of the bolt as far as the motor goes right?? Gosh I wish I would've ziploc'd them. Thanks!
#3 | |
![]() Join Date: Jun 2009
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
![]() Join Date: Jul 2015
ive got a motor off the truck that i think has the hardware i'll go check in a few
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Beat me to it!
Appreciate that guys. If you could tell me the size of the thread and how long I can probably pick up at hardware store. A photo might help with the arm assembly but I don't want to hassle anyone too much. I'm impressed with our Wilco Farm supply hardware collection from black chrome to stainless.
Well, take the free ones......both the wiper motor mounting bolts and the wiper link assembly mounting bolts are special.
They are not "normal" bolts, and no one, I mean no one, reproduces them. They have a beveled surface between the head and the threads to center the motor and the link assembly. The wiper motor bolts are longer than the wiper link bolts. |
![]() ![]() Join Date: Feb 2009
Coincidentally, Getting ready to write up my notes now....Here you go:
The motor mounts using three 5/16" head machine screws with integrated "cup" star washers. The screw threads are #10 x 1" & 24 TC. Each wiper transmission uses two 5/16" head machine screws with integrated "cup" star washers. The screw threads are #10 x 1/2" & 24 TC. "Cup" meaning the little star washers form to the bottoms of the heads.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Thanks a mucho 71ChevyShortbed402 I might get lucky at the hardware store but I'm not holding my breath.
#10 | |
The Older Generation
Here is a picture of the wiper machine screws. I don't think you will find them at a hardware store. You need 3 of the long ones and four of the short ones. LockDoc
That's the little fellows "integrated cup star washers". I don't know what else to call em. Hardware store? Good luck with that. I couldn't even find a screw for a washer jet today, Napa or Lowes. Napa had similar, but #8 and they use #10.
Carpe manana
![]() ![]() Join Date: Dec 2010
Here's a pic that might be helpful: http://67-72chevytrucks.com/vboard/s...2&postcount=58
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Good stuff, thanks a lot gentlemen, I know what I'm looking for now.
They are all on there way to you my friend, you have new bolts and mounting pads for the motor on the way from brothers and I have the transmission arm bolts on the way in an envelope I pulled from a parts truck I have.
![]() Happy trucking my friend ![]()
#15 |
Larry you are a gentleman and a scholar (remember that?) I sure hope your return address is somewhere so I can send you something even though I know you don't want anything. Thank you!
#16 |
The motor bolts I had were rusty and snapped when I tried to remove them so I figured new ones would work best. Nothing owed here just pay it forward somehow if you like.
#17 |
You're a good man Larry. "Keep on Truckin'"
