steering column
I just bought a 68 swb step side. the guy that had it put a (looks like mid 80s)steering column in it but it moves up down all around.It also has the pull bar type e brake. Is there some type of a clamp that clamps that besides the e brake bracket. Thanks in advance.
95 sfa 38.5 swamper TBI vortech 68 chevy stepside |
The column should be clamped in two places, at the floor and underneath the e-brake. You may have to put another column in it as the later model may not bolt up without modifying.
Jim |
Under the e brake bracket is a strap held in with 2 bolts that hold the column tight to the dash, out on the firewall is a plate bolted to the firewall with a rounded perch that a band clamp fits on to hold the column. Any 2" dia column will usually fit these trucks if they have no ignition switch in them with a little work.
Rest in Peace Ed. Thanks for all the good times. |
thnk you very much for the info.
It has the band thing on the firewall. But no clamp under the dash. Does anyone know where to get the clamp from? Ive looked in a couple catalges but couldnt find it. thanks
its all about the +6 inches
If it is a late model column (with key and wiper switch) then a stock one probably won't work due to the larger diameter of the later column.
OK it is the later model with the key and wiper switch. Maybe Ill just switch it back.
