Old 03-16-2017, 07:17 AM   #1
dccubby
Headlights
I know there have been many threads about headlights, but i have not seen any recent ones. i am looking to purchase new headlights and was thinking about going to LED. Just curious if anyone has installed any of these.
I was thinking of something like this
http://www.ebay.com/itm/7-Stock-Styl...XcvDJ&vxp=mtre
i dont want the halo rings
thanks
dccubby is offline   Reply With Quote
Old 03-16-2017, 08:50 AM   #2
JustToxic
JustToxic's Avatar
Re: Headlights
Personally, I would stick with Halogen or HID. After dealing with LED kits like that and having zero good things to say. The HID is going to allow you to see further and you'll be able to aim your headlights better. I bought a set of LED's off ebay for another project and had nothing but issues. I finally just converted that kit over to HID.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 03-16-2017, 08:55 AM   #3
dccubby
Re: Headlights
Ok i am good with HIDs, but do they have high/low or just high. And i have read that you need to order a resistor or relay. Do kits come with these?
Old 03-16-2017, 09:03 AM   #4
hdff
hdff's Avatar
Re: Headlights
a headlight relay harness is good to add even if you keep your old lights, easy install. as far as I know resistors are needed for led tail and turn signal lights to stop a hyper flash, which they now have flasher relays with one built in to stop that, shouldn't need one anywhere else. Halogen bulbs should be plug and play, hid are plug and play except you will have to mount the ballast box that they need to start, they are small and each light will have one. yes they have hi/lo, I put some on a motorcycle one time. check the web site for DDM tuning, that is where I got mine, they have lifetime warranty ballasts, and many choices for bulb color. but there shipping is slow, like 3 weeks from japan
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 03-16-2017, 09:05 AM   #5
JustToxic
JustToxic's Avatar
Re: Headlights
The few kits I have bought have come with everything you need to make them work. On the high/low side of things, when your looking for a certain kit make sure it says it'll do both, some will come with two bulbs for one housing. I've bought them both ways, so its really all on what you find if your using ebay.
Old 03-16-2017, 09:10 AM   #6
dccubby
Re: Headlights
Ok thanks. I don't care about using ebay, i just dont want to pay 400 for a set of headlights
Old 03-16-2017, 09:14 AM   #7
hdff
hdff's Avatar
Re: Headlights
http://www.ddmtuning.com/Products/UltraHIDKit I am not affiliated with this company but have used them before...... choose bulb color depending on what color you want your light. I prefer crisp white 5500k , the lower the number the yellower the light, the higher the number the bluer the light. they even have a relay harness
"Wanda"
Old 03-16-2017, 09:15 AM   #8
JustToxic
JustToxic's Avatar
Re: Headlights
I've used this website before for HID stuff. https://www.hidnation.com/collection...onversion-kits
Old 03-16-2017, 09:17 AM   #9
dccubby
Re: Headlights
Thanks guys im going to order some today, i just have to find the glass housings too.
Old 03-16-2017, 09:22 AM   #10
JustToxic
JustToxic's Avatar
Re: Headlights
If this helps here is the housings https://www.summitracing.com/parts/sum-899250/overview/
Old 03-16-2017, 10:22 AM   #11
54blackhornet
54blackhornet's Avatar
Re: Headlights
Get yourself a set of Hella H4 ! Quality Quality Quality ! Pop in a Sylvania bright white bulbs and you will be good.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-16-2017, 12:30 PM   #12
StingRay
StingRay's Avatar
Re: Headlights
Bosch, Hella or any of the vintage Cibie, Carello or Lucas. Like a camera good optics are critical. Good bulbs and wiring that can handle the current are also important. It's really hard to beat good old fashioned H4 European lights. Best I can recall Cibie actually used Lead crystal on some of the old light lenses. I worked for a Cibie dealer in the late 70's and I have a vintage Cibie optical aimer. I also collect every old quality light I can get. Lots of them make their way onto projects.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-16-2017, 12:51 PM   #13
Z10
Z10's Avatar
Re: Headlights
I used these LED bulbs and they work great! http://www.ebay.com/itm/252295580117...%3AMEBIDX%3AIT some before and after pics. The other bulb is a standard H4.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-16-2017, 12:56 PM   #14
davepl
davepl's Avatar
Re: Headlights
I run 4-beam HI/LO KenSun HID in my GMC truck. There are a total of four transformers, so it's a bit of wiring, but the result is nice. I'm using the H4 housings from LMC (I think they're H4 anyway) and then the HID lamps on those.
Sometimes eBay HID can be a ticket to despair - glare, bright foreground, and a bunch of other things that don't help you see further. But so far I'm pretty happy with them, and you get a crisp cutoff line.
I also had one burn out that I'm sure was out of warranty and they sent me a free replacement. When that one turned out to have a slightly different color, they sent me yet another free replacement. So great service.
Check out KenSun.com, but they're all over eBay.
Remember to keep the color temp at 3K or less if you don't want them blue looking!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-16-2017, 06:24 PM   #15
Willie Makeit
Willie Makeit's Avatar
Re: Headlights
This.
I know of no current housings in a 7" configuration that are manufactured in a fashion that allows for proper LED light distribution. In other words, you can't just pop in LED elements in any ol' housing and expect good results.
Save yourself a ton of aggravation and disappointment and go with Bosch E-codes, a set of quality bulbs and a relay harness.
Willie Makeit is offline   Reply With Quote
Old 03-17-2017, 12:23 AM   #16
El Dorado Jim
Re: Headlights
LMC truck has H4 7" lights and harness , I bought a set for my suburban and love them.they look almost stock.and what a huge difference in lighting up the road at night.I bought a set for my 72.just a few weeks ago..not sure I like the look of them, they look too modern, they changed the style since I bought my other ones so I bought some Hella lights off Amazon, they look almost original,will use the Hella lights with the harness / relays from LMC
El Dorado Jim is offline   Reply With Quote
Old 03-17-2017, 12:28 AM   #17
El Dorado Jim
Re: Headlights
Originally Posted by JustToxic View Post
these are the ones that LMC has now....not original looking but I'm sure they are very bright
Old 03-17-2017, 12:30 AM   #18
El Dorado Jim
Re: Headlights
https://www.amazon.com/HELLA-0023959...EVD7EF2JHA2A5E these are the ones I bought
Old 03-17-2017, 10:29 PM   #19
Mollzyie
Mollzyie's Avatar
Re: Headlights
Great links and info guys ! .... anybody ever tried projector headlamps ?
M.A.G.A.
Mollzyie is offline   Reply With Quote
Old 03-18-2017, 09:46 AM   #20
snj8198
snj8198's Avatar
Re: Headlights
I went with the Cibie H1 & H4 headlamps and bulbs combo with relay kit wired so all 4 headlamps come on giving both flood and pencil beam on high. The difference over stock is amazing. In fact, it's better than many new car light configurations. Make sure they are aimed properly.
http://danielsternlighting.com/products/products.html
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 03-18-2017, 11:42 AM   #21
HO455
HO455's Avatar
Re: Headlights
I have not, but my understanding is that to work properly projector lights require a deeper housing than any bolt in conversion light will allow. Plus there is no OEM engineering behind them to ensure quality optics and beam pattern. So personally I would avoid them.
RIP Bob Parks.
Old 03-18-2017, 12:00 PM   #22
elf w/capital T
Re: Headlights
When you put hid in these kind of headlamps, you have great lighting but do glare badly for others and they will blink you, unless you find ones with a projector with a cutoff in them... but hey its your truck and do what ya want!
elf w/capital T is offline   Reply With Quote
Old 08-23-2018, 09:22 AM   #23
CBH
Re: Headlights
Hey thanks but it's my turn signal and park lights after putting in a digital dash.
CBH is offline   Reply With Quote
