Door hinge adjustments?
I am needing to adjust the upper door hinge on the drivers side of my 69, need to move it back towards the rear. Any way to slide the hinge back without pulling the fender? I do have the cowl off, and was wondering if I pull the two bolts for the fender (at back, top, that are usually under the cowl) can you pull the top of the fender out enough to get at the hinge bolts???
Any ideas or suggestions would be greatly appreciated!!! Squid
'69 C10 LWB- 305, Holley 2 barrel, 700R4, 4/5 drop, dark blue primer!, cheap driver project... Back on the road... In time to sell on Ebay. ![]() |
I don't believe that you can pull the fender out far enough to do you much good. I use a 1/4" ratchet with a 9/16" socket and a 9/16" open end, boxed in wrench along with a door hinge wrench.
It takes a little maneuvering but using one of the three wrenches listed will work. Here is a pic of the door hinge wrench. Jim |
The LuvShack Garage
Is that homemade, or does someone actually sell that
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() ![]() Join Date: Jul 2002
Yes, curious minds would like to know, because I sure do want one for the toolbox.
"door hinge wrench", where the heck have I been? Never seen that before!
~Rest In Peace~
sear craftsmens used to have those wrench sets too
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
67-72 Addict!
Snap On sells "S" shaped wrenches and Door hinge ratchets.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Right on! Thanks for the replies!!! Guess I will try to find one of those quickly.
Squid
Is a bullfrog waterproof?
Squid, you better have deep pockets if you buy a Snap-on. My brother in law has a couple of those that came from Snap-on about 35 yrs. ago and they were expensive then. They sure are handy.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt." Ben Franklin __________________ 1970 Chevy shortbed 2002 Harley Custom Chopper (Long sucker) 1998 K2500 5.7L 5-speed Longbed 1st two are My son's toys...they just live in my garage! 1997 GMC K1500 Suburban 1993 S-10 Blazer 4D (youngest son's daily driver) 2000 Dodge Ram 4WD Ext. Cab (5.9L) Wife is a late year 1951 |
Re: Door hinge adjustments?
Looks like the S O logo, almost can make out the part #, it will be spendy. When I did mine I removed the fenders completely, left the inners in place.
Get a set of S wrenches from Harbor Freak or sacrifice a 9/16 from the tool box and heat and bend it . You can grab a set of them offset ones from HF and heat and bend them
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
I just bought this wrench. I hope it works for the door hinge. http://www.ebay.com/itm/WESTWARD-1LC...8AAOSwT6pVku43
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
![]() Join Date: Feb 2016
I have one of these I used for my doors. Called a half moon or obstruction wrench. They are not hard to find. Or if you have a long reach wrench and a torch they are easy to make. I have even made a custom version with a cut off ratcheting box end and a piece of pipe to it welded to it.
https://www.summitracing.com/parts/s...MobileSwitchNo
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
You don't need anything special and you don't need to remove fender, it sucks but I have done it a few times and yes it brings the suck.
#15 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-16-2017 at 09:56 PM. |
